Tip & How-To about Office Equipment & Supplies
The driver for a particular operating system is not available?
Answer:-- This is due to many reasons but mostly its due to as follows :-- Whenever the New operating systems are released, new drivers will need to be loaded for your existing printers. Not all printers have a driver for every OS. In these cases, it’s best to consult the printer manual and find out what printers the drivers will emulate. While not all of the functionality of the printer will be available under this emulation, at least basic printing will work. For example, most HP printers will print with the HP Laser-Jet II driver installed, although specific options, such as duplexing, will not work. this will help.good luck.
I just bought Intel ATOM D425 MB. I installed winxp. Everything ok. But Network drivers not installed. In device manager it shows as unknown device. I searched the Intel site.They dont also have the LAN driver for XP. Please help
OF COURSE there are no Windows XP networking drivers for this Intel motherboard. WinXP was released in 2001; this motherboard wasn't even DESIGNED until XP had already been replaced by Windows Vista and Windows 7. Why would Intel ever bother to make drivers for an OLD operating system for NEW hardware?
You bought NEW hardware; you need a NEW operating system to make it work. If you want to use XP, you won't be able to do any networking with this system. If you want to be able to network this system, you'll need to buy a modern operating system for the modern hardware.
I know this isn't the answer you want to hear, but you also won't find Microsoft writing a NEW operating system to work with my OLD AMD 386DX-40 motherboard. Of course, you can always complain to Intel and Microsoft, but that won't change the reality. You have NEW hardware, which is great, but NO ONE is going to design and write NEW drivers for an OLD operating system to work with your new system.
Apr 27, 2011 | Intel D425KT Innovation Series Motherboard...
My Buffalo 1TB Ext.Hard drive is not showing on my list of drives on my computer. It shows (in the device manager) an error Code 10..What does this mean?What can I do to fix the problem? Thank you
Almost all Windows operating system users come across system errors at one time or another. A flickering or blank screen, frozen cursor, blue screen, or an unexpected system restart are all indications of a system error. Most of these errors display an error message that you can use to troubleshoot and fix the problem. In this article, we will learn about the code 10 error and then have a look at common causes of system errors and methods to prevent them.
How to Fix a Code 10 Error
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
Dec 17, 2010 | Buffalo Technology 1TB DriveStation...
Blue screen. 0x0000008e (0xc0000005,0x80409A88,0xf789e360,0x00000000.
This error occurs due to the following reasons: Faulty RAM, registry errors, incompatible drivers, hardware failures, faulty BIOS configuration, Viruses.
Follow the steps below to avoid the BSOD error message occurs again.
Check whether the RAM installed in your computer complies with the motherboard specs. Replace the RAM if needed. You can also check the systems with a friend's RAM to know whether the error message is due to RAM.
Use a free registry cleaner/fixer software available to clean/repair your windows registry. (Ccleaner is good at this)
Do not install incompatible device drivers. Install only Microsoft Signed drivers. Update your existing driver software from the corresponding device manufacturer's website.
If you have installed/changed new hardware, check whether it is supported by your system. Also check whether it is installed properly. If needed test the systems without the faulty hardware. Check whether you've installed correct/signed driver software for that particular hardware.
If you have reconfigured your system BIOS, set it to default/optimal/recommended settings and test the system. Disable features like BIOS caching.
Use an original and up to date antivirus system like Norton, McAfee or Kaspersky and run a full systems scan.
Keep your windows updated with current patches and fixes to protect the systems from unwanted troubles.
All the best.
Mar 06, 2010 | Microsoft Windows XP Professional for PC
i want to upgrade this printer to a new computer, but i lost the cd installation for it. is there any ways i can install the software for this printer into this new computer?
Okay, let me make sure I understand you.
You have an HP printer and you purchased a new PC, correct?
We need to know what is the operating system for the new PC.
Next you need to check the HP website to see if HP has released a printer driver for this operating system.
For example, I have WINXP. If I upgrade to WIN7, I need to go to Lexmark's web site and see if the printer has a driver for WIN7.
If there is not a new driver, then I need to use the ADD Printer Wizard and use a generic printer driver.
Feb 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
125 people viewed this tip
k24674
jasbo
jasbo
