Tip & How-To about Office Equipment & Supplies
There are many possibilities .The most common are as follows:--
First, the fusser assembly may be damaged or at the end of its life. The solution is to replace the fusser assembly. Repairing a fusser assembly is generally not recommended because the fusser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time. In a black-and-white laser printer, the solution is to replace the toner cartridge. In a color laser printer, only replace the cartridge that is exhibiting the problem. Third, some toner may have spilled in the printer. If so, you'll need to clean it out.
This will help.good luck.
Problem Description:
The end of life of the Prime Assembly has been reached since it has been working for more than 58 hours.
Corrective Action:
Try the following:
Replace the Prime Assembly.
You will need to replace the Prime Assembly PN Q6670-60062
