Tip & How-To about Computers & Internet
Speed Up Windows Computers
These are techniques that computer technicians in several different support organizations do and some charge a lot of money for their walking you through these processes.
Step 1: Scandisk
You should run scandisk at least once a month. This will make sure that your computer can read all of the information on your disk. How will this speed up my computer? I'm glad you asked! You see your computer has in it's hard drive what the technicians call redundancy. What I mean is if your computer is trying to read a file and the data isn't read correctly from the disk, the computer tries to read that information again and again a set number of times. This results in slower loading times. When scandisk is ran regularly this keeps your disk free of these storage errors and thus enables the computer to get the information it needs from the disk as fast as possible. Scandisk should be run before the next step each and every time.
I know you're asking, how do I run scandisk. It's simple. Find that icon on your desktop or in your start menu labeled 'My Computer'. In there you will see a listing of all the drives in your computer. Right click on the drive you want to scan and go to properties. There, you will have a tools tab. Click on it. You will see a button that says check for errors. This is scandisk or also called checkdisk on different versions of windows. There are 2 different modes, Standard or Thorough. Standard checks and makes sure that all the bits and pieces of your files are in the spot on the disk where it thinks they should be. In other words, it checks for filing errors. Thorough does a standard check as well as it tests each spot on the disk where the drive can write something and makes sure that what it writes, it reads back the same thing. If it doesn't read the same information back, it marks that spot as bad so that it is not used. This keeps down that redundancy thing we spoke of earlier. Wasn't that easy?
Step 2: Defrag
Defrag should be run once a week if you use your computer more than 14 hours a week. This equates to about 2 hours a day. Most people who actively use their computer will fall into this category. Defrag, whose real name is disk defragmenter, is your best friend for speed. You see when your computer writes something to the disk; it starts the disk to turning and drops bits of the data you want to write wherever there is a hole. It then tells the filing system where it placed that piece. So your file could be literally broken into 20 pieces! Your disk takes longer to load the file because it has to jump around to different spots to gather the pieces together when it needs it. Defrag takes care of this by gathering the pieces all together and writing them back to the disk in one piece. This way when you need the information, it's all right there. To run defrag it's the same as where we went for scandisk. You go to 'My Computer' and you right click on the drive you want to run defrag on and go to properties. There go to the tools tab. Click the Defragment button. Wow this is getting easier by the minute! On to step 3.
Step 3: Background Programs
Background programs really slow down your computer's performance. They accomplish this by using up your computer's resources. Resources are the combined power of your processor (brain), memory, and disk space. These 3 are the equivalent to horsepower. This is where you will gain a lot of your speed back as well. If you look at an area of your screen right now, I can show you a fraction of some of these that you never thought of. The area I want you to look at is called your system tray. It is located next to your clock, which is opposite your start menu. If your start menu is on the left side, then the clock is on the right. Next to the clock you will see these little icons or pictures. These are programs that run on your computer whenever it boots. Guess what, these are background programs. They are there to help load things you need faster. If you are following this guide you really don't need most of them. Do you?
Here's how you get rid of them and most of the others that you can't even see as well. Sorry folks who are on Windows 2000, this step won't work for you. If you read to the end I will give you a bonus that will make up for it, I promise. Ok, for the rest of you, click on start. Click on run. Type msconfig. Click ok. You should get a system configuration utility. Be very careful here and follow my instructions exactly. Click on the startup tab at the top. You will have a list of all the programs that run when your computer boots or starts. If you look down the list there will be some names that are familiar to you. When you see those names I want you to think: "Do I really need this program running all the time?" If the answer is no, uncheck the box. For example, some of you may have heard of RealPlayer. There's a smart start icon associated with it. You really don't need real player running when you are only going to be playing FreeCell now do you? :) On to step 4.
Step 4: Temporary Files
Temporary files hold up space on your disk. These files are most of the time useless. Temporary files are just that; files that were temporarily created by a program or installer. They are supposed to be deleted when not needed any longer, but a lot of programs do a poor job of cleaning them up. Helping them out will get you more speed for your horsepower. For example: let's take temporary internet files. When you go to a website every element of that website's decorations are stored in a temp file on your computer. Your computer does this to help supposedly. It's supposed to help by when you visit the same site again; the elements of the website will already be on your computer and therefore don't have to be downloaded again. This in theory should speed up your surfing right? Wrong! Here's what really goes down. For every element of the website, your computer reads every temp file to see if it matches. Every single file in your temporary internet files folder! To get a grasp of this here's what I want you to do. Open internet explorer. Go to the tools menu and click on internet options. Click the settings button. Then click the view files button. Do you see what I mean? Every file! Now...Close the temporary internet files window. Click OK on the settings window. Do you see that button next to settings on the internet options window? It's labeled delete files. Click it. Check delete all offline content. Click ok. When the hourglass is gone, you are all clean! This should be done once a month. This will keep your whole computer running smoothly. The secret lies in Internet Explorer. It's integrated so much into windows, when it has a problem, windows has a problem. What I am saying is when you opened my computer in steps 1 and 2. You were using internet explorer. Ok. Nuff said. On to step 5!
Step 5: Antivirus
Good Antivirus software is an absolute must! There are several choices to choose from. Some cost money and some don't. Viruses hide on your computer and wreak havoc. If you don't have antivirus software on your computer, you will never know they are there. They sit and hide out until their appointed time and then interfere with your computer. Viruses are programs written by people with too much time on their hands and not enough morals. They sit and think of ways to make your day bad. Some viruses will sit on your computer and do nothing but open up connections to other servers all over the internet. What does that do? It slows your computer down drastically! Nuff said. Your choices are to get paid antivirus software like Norton, Mcafee, or Computer Associates. If you don't have the cash to spare then you can go to your favorite search engine like Yahoo or Google and enter in 'free antivirus download' and get a list of all kinds of scanners. Some is far better than none. Some of the best free software that I have found are AVG, Avast!, and ClamWin. If you have a fear of installing software, never fear. There are also free online virus scanners. Again, you go to your favorite search engine and type in 'free online virus scan' and you will get plenty of results. Beware though, with these scanners you run the risk of getting infected still. The reason is you have to go to the site and scan the computer yourself, preferably once a week. In that time a virus could have already infected your machine. Antivirus software that you install on the computer checks every file, every time it's used thus drastically decreasing the chances of infection. It's like a flu shot. Some of the good online virus scanners are Norton, Panda, and BitDefender. Now, on to step 6.
Step 6: Recycle Bin
It is very important to keep your recycle bin empty. What I mean is this, you don't want to have hundreds of files sitting in your recycle bin that you deleted 6 months ago. They are taking up valuable space. Windows uses your drive as memory to run programs. When you run out of physical memory, it uses what's called a page or swap file and stores it there. These recycle bin files are taking up space that windows could be using for memory. Every bit of memory you can get adds to your horsepower. So for God's sake, please keep your recycle bin tidy. Get rid of things that you are sure you won't need again. When you go to delete something, and you are absolutely sure you won't need it again, you can hold down the shift key and press the delete key to permanently delete it without sending it to the recycle bin.
S
Computers & Internet Logo
Will coughing vigarestly save you from a heart attack
no
in fact it may bring it on
sever coughing places strain on all of your organs including your heart
go see a doctor or cardiologist for a proper diagnosis
Aug 17, 2017 | Cars & Trucks
Aveo 80,000 miles 2009. Acts like it doesn't get fuel. Jerks, and dies. Keeps this up, and then maybe takes ooff real fast. Especially when it is warm out.
Well that's where doing some testing comes into play . Instead of asking on here an expecting a magical fix , learn how to test an lean about the different systems on your vehicle . Test the fuel system , fuel pump pressure an flow , testing electrical circuits with a DVOM - digital volt ohm meter . Eliminate thing's that are right . Find service information manual so you know what the fuel pressure is suppose to be , how much current the fuel pump is expected to draw . Also the electronic ignition system specification. I think it's cool you want to find out about you vehicle , but go to school an learn about it the right way . Because listening to someone guess will get you no where . Your vehicle is a rolling computer , has a lot of electronics . Electric Testing Techniques You Need to Know Motor Age TST New Battery Starting Charging System Testing Techniques
Fuel System Diagnosis Presented by Delphi
If you don't understand any of this , do yourself a favor an take it to a qualified repair shop . Repair modern automobiles isn't easy , even for seasoned Technicians .
Mar 06, 2017 | 2005 Chevrolet Aveo
cant log in forgot pass word need new pass word
You need someone else with a computer. Download NT Password deleter here:
http://pogostick.net/~pnh/ntpasswd/
Press F12 on startup to get the boot options, select yr DVD/CD drive and this will reset your password.
Alternatively find a local PC repair guy. If they're any good they can do it in 5 minutes for a nominal charge. If they try to charge lots of money walk away. It's an easy fix if you know what you're doing.
Sep 09, 2013 | Computers & Internet
arthritis knee pain makes walking difficult is there any solution to this problem
Try Organic Magnesium spray.
Spray on effected joints.
Is on temporary relief about 12 hours so you need to apply this daily.
Jul 03, 2013 | Health & Beauty
The fan squeaks so loud! What can be done?
you can do it your own without going to the technician spending money , actually the technician do is only to get the motor and they will send it to the machine shop for converting it to bearing from bushing, most of the aircon motor is bushing that's usually the cause of squeaking coz the bushing is out lubrication and worn-out already, using sealed and lubricated bearing you can achieved a longer life of a motor and is so quite also . anyway, by doing this all you have to do is to prepare your tools ,do it your own ,dismantle it in organize manner, then get the motor and disconnect all the wiring and be sure to put mark on it so that it will be easy for you to reassemble. the payments you spent is only for machine shop ,i'm sure if go to the technician it will put many job in a quotation and they charge you a lot.
Dec 09, 2007 | Goldstar R1003 Air Conditioner
126 people viewed this tip
David Payne
David Payne
