Tip & How-To about Cell Phones
Download Files From Rapidshare To Windows Mobiles With wmDownloader
Whenever you need to download any file online from various softwares, you have to keep your PCs on till the download is complete. And in case you need to go somewhere and turn off your PCs, the downloading stops there and then. Also you might not want to keep your computer running behind you for personal reasons or for the sake of power-cut when you are not there. wmDownloader v0.20 is the solution to all these problems. This application allows you to easily download files from One-Click-Hosters like rapidshare.
It can be used to download your files overnight without the use of PC, but remember to plug your PocketPC to charger. Turning of not cheap GPRS data connection in case of WiFi lost connection is recommended
HOW TO INSTALL/USE THIS APP? After first start go to “Config” tab, select destination folder for your files and click “Save”. Now you can add files in “Files” tab or by editing file “files.txt” and then reloading it using “Menu->Reload files.txt”.
When you added some files you can start the download process. Files will be removed automatically from the list after download.
Cell Phones Logo
powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Jul 27, 2015 | Microsoft PowerPoint 2003 for PC
I have a samsung mobile b3410 but whenever i used to play youtube video file it doesn't open ... it says content not supported so what is the solution of it...
Your samsung mobile b3410 best supports videos of 3gp and mpeg4 format, but the video from youtube is flv format. So you need to download a video converter to transform the youtube files. You can try this software, youtube downloader, which can download videos from various popular video-sharing sites, and convert all downloaded videos or local video files. It can certainly convert your flv files to mpeg4.
Nov 21, 2012 | Cell Phones
cn't download 1240 software
Are you installing using CD or online? Make me clear to assist you further.
As the Win 32 software error comesup when the file is missing.. generally possible in case of online installation.
Dec 31, 2008 | Lexmark X1240 All-In-One InkJet Printer
malware threats
What your seeing is called Adware, they are trying to make you think you are infected to buy their software to remove it.
What you need to do:
Go to www.ewido.com a reseller of AVG, download the software and run a FULL scan once complete delete the threats its finds.
Thanks,
Cameron Bradford
www.pc-fix.us
Oct 20, 2007 | Microsoft Windows XP Professional With...
118 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
