Tip & How-To about Office Equipment & Supplies
The ghost image of the print is printing on the paper with the orignal print ?
Ghosting is a condition where theimage prints properly, but a much lighter copy of the image also printselsewhere. This can be due to a problem with the power outlet that is supplyingpower to the printer. Check the power outlet by plugging in a different printerto see if the same results occur. Ghosting can also be caused when consumableprinter parts (such as the drum or imaging kit) are near the end of their life.All of the consumable parts in a printer are rated for a certain number ofpages. Once a printer gets near that magic number, you'll need to replace thoseparts to eliminate ghosting.
This will help. good luck.
the black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Printer is ghosting - I have changed power supply
Might be your transfer roller. I would try some laser cleaning paper and run that through a few times. If that doesn't work, I would purchase a fuser maintenance kit which will have the rollers as well as a new fuser.
Dec 15, 2008 | Brother HL-2040 Laser Printer
print smudges and ghosts down the page
Usually ghosting is caused by the fusing unit, which usually means that it needs replaced to be honest. You could try getting into the fuser and giving the rollers a wipe, they may have dry toner on them which could also cause the fault. but i'd say the fuser could need changed!!!
Hope that helps  (",)
Dec 11, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
401 people viewed this tip
jasbo
jasbo
