Tip & How-To about Computers & Internet
Back up
Don't ever ever to forget to back up your data regularly. this will save you a lot.
Computers & Internet Logo
i have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some assistant
Don't be panic. you can try some format recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
my hard disk on nx9420 failed (i get the message 'critical error - imminent hard disk failure, save all your data'; but the computer will not boot (just says press 'control alt delete'). how can i save data if i don't have restore disks with me?
This warningmeans the hard disk will fail sometime in the near future. You need to back upyour data regularly before the hard disk fails or you will lose your data.
When the hard disk fails, you need to replace with a new one and installWindows on the new hard drive to get your computer working again.
If you cannot boot up your computer then -
Remove the hard driveand connect it to an USB hard drive adapter and plug it into a workingcomputer's USB port. If this computer detects it as an external storage deviceand you can open the various folders and files then back up your data.
If not you are in trouble, there are companies that can recover data fromfaulty hard drives BUT it will cost you an arm and a leg for their services.
Jul 18, 2011 | Computers & Internet
my phone book got formatted. i have lost all my contacts. any way i can retrive my lost data? please help!!
Unless you had a back up solution in place such as syncing or an application that ran regular backups you are probably out of luck.
Sorry
Jun 27, 2011 | Cell Phones
I have data stored on the simple drive that I saved (Favorites list, email address book, pictures, etc.) Everything had to be taken off my computer due to a virus & rebuilt...how do I get this information back on computer?
Hi there,you can try a data recovery software.I have succeed to recover data from flash drive with Tenorshare data recovery.It can recover data after deeply scanning your flash drive to look for lost data.
By the way,you can download a trial version and scan your flash drive for free to check out whether your data can be recovered. http://www.any-data-recovery.com/index.htm
Jun 12, 2011 | Computers & Internet
how to recover from format error message in walkman
Format error are often shown if the file stored on your Sony NW-E505 is not recognized by the system. Try to review the supported audio formats of your player,use audio (format) converter for better compatibility.
Aug 27, 2009 | Sony NW-E505 MP3 Player
127 people viewed this tip
David Payne
David Payne
