Tip & How-To about Computers & Internet
How to enter bios in sharp
Computers & Internet Logo
when try to boot up it says operating system not found Thanks
This error comes when your harddrive is not detected properly or some os system files are missing.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios then make sure your harddrive is recognized in bios if not then make sure SATA is disable then save settings .Then check.
If still same then you need windows disk or recovery disk to repair your windows missing files.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 12, 2010 | Sharp Actius AV18 Notebook
I have misplaced the recovery CD for Sharp Actius RD3D PC Notebook and I need to re-install the Operating System, so I requires Drivers for its hardware components, Also if possible an another official recovery CD from sharp..?
You do not need the CD to recover this laptop.
From the User Manual:
1. Turn on your computer. When the message <F2> to enter System Configuration
Utility appears on the bottom left of the screen, press F2. Then, the Setup Utility
will open.
2. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
3. In the Exit menu, confirm Exit Saving Changes is highlighted and press Enter
twice.
4. The system will restart. When the message Press F10 to Recover appears on the
screen, press F10.
5. Read the message on the screen, and select the way to recover your system; then,
press Enter. If you selected Formats hard disk and creates new partition, go to
the next step. Otherwise, go to Step 10.
6. Select the volume of C: drive and press Enter.
7. Read the message and select Continue; then, press Enter. The formatting and reinstallation
will start.
Although the pointer may be shown on the screen, never touch the
keyboard or the mouse during recovery except when the message prompts
you to. If you touch them, the re-installation will be canceled.
8. When the re-installation process is completed, the system will restart
automatically.
9. Set up Windows XP by following the on-screen instructions. When you complete
the Windows setup, make sure to set date and time.
If you need help understanding these instructions, feel free to ask.
Jan 08, 2009 | Sharp Actius RD3D Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Problem with keys used to enter the cmos
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
    If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below).
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Mar 17, 2008 | Toshiba Satellite 5005-S504 Notebook
2,674 people viewed this tip
Alun Cox
