Tip & How-To about Gateway M305CRV Notebook
How to enter bios on gateway
Gateway M305CRV Notebook Logo
I need to know how to access the BIOS of a Gateway GM1100 Desktop
  • Press the F1 key repeatedly after restarting the computer.
  • Sep 26, 2014 | Gateway Computers & Internet
    my gateway is stuck in configure 3 of 3 at start up
    Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
    Jan 22, 2013 | Gateway Computers & Internet
    how do I enter bios on Gateway desktop 835 GM?
    All of Gateway's desktops use the F1 or F2 keys to access to the CMOS setup. Turn off your PC, and power on the PC. Press the F1 or F2 key immediately in one second intervals when you see the initial screen displaying the BIOS.(Try F1 key first, if it does work try F2 Key) Hope it helps.
    May 28, 2011 | Computers & Internet
    I need to access the BIOS on my Gateway GT5428 PC
    well, the most common BIOS entry keys are F1, F2, F10, and Delete.
    push one while the computer is booting, before windows starts booting.
    Mar 26, 2009 | Gateway Computers & Internet
    Toshiba Satellite 1400
    To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
    Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
    • Press Del or F2 immediately after powering on.
    • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
    • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
    Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
    • Press F10 while the cursor in the top right corner of the screen is blinking.
    • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
    Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
    • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
    • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
    • Older Dell laptops may use Fn+Esc or Fn+F1.
    eMachines - eMonster, eTower, eOne, S-Series, T-Series
    • Press Tab or Del while the eMachine logo displays on screen.
    • Other eMachine computers may use F2 to enter BIOS.
    Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
    • Press F2 once the Fujitsu logo appears.
    Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
    • Some older Gateway computers use F2 to access the BIOS Setup utility.
    Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
    • Press the F1 key after restarting the computer.
    • HP Tablet PCs may use F10 or F12.
    • Other HP computers may allow access to BIOS using the F2 or Esc keys.
    IBM - PC, XT, AT
    • Press F1 immediately after powering on the computer.
    • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
    Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
    • Press F1 or F2 after powering on the computer.
    • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
    Micron (MPC Computers) - ClientPro, TransPort
    • Press F1, F2 or Del immediately after powering on the PC.
    NEC - PowerMate, Versa, W-Series
    • Press F2 to enter the BIOS Setup.
    Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
    • Press F1, F2, or Del to enter BIOS.
    Sharp - Notebook Laptops, Actius UltraLite
    • Press F2 after the computer starts.
    • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
    Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
    • Press F2 or Del on startup.
    Sony - VAIO, PCG-Series, VGN-Series
    • Press F1, F2 or F3 after turning on the computer.
    Toshiba - Portégé, Satellite, Tecra
    • Press F1 or Esc after powering on to access BIOS.
    The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
    ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
    Cybermax - Press the Esc key.
    Tandon - Press the Ctrl+Shift+Esc keys.
    Good Luck and Hope it helps...
    http://www.wnycomputerpro.com
    Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
    4,349 people viewed this tip
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
