Tip & How-To about Washing Machines
Ge/ hotpoint washer overflowing
The problem is in the pressure switch hose. witch is located in side the washer on the tub. remove the front by pushing 2 clips in between the gap of the top and the front. i use a flat blade screw driver some use a putty knife. you will find the clips to be about 2" from either side now that you have the front lose. you can remove by pulling it towards you and lift up.
the hose is on the left side of your tub. pull the hose of and stick something up in to hose. i use a pc. of wire. you will pull out some clear or black de bree. i the use a turkey baster to forces air into tub from where the hose was attracted. cut of 3/4" off the end of hose put back on and put the front back on just set it on the 2 lower clips and push. pat your self on the back your done. make sure you try it
Washing Machines Logo
Washer overfills. Water does not stop filling on any cycle.
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, however, read the following link:
http://www.fixya.com/support/r3575901-washer_overflows In many cases the small air hose on the pressure switch can come loose from the pressure switch and cause the symptoms you are experiencing. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If the air hose is intact, check the entire length of the hose from the pressure switch to the air dome on the wash tub to ensure it is not leaking anywhere. The air hose is how the pressure switch senses the pressure differential as the wash tub fills. Without it, and the pressure switch will not work. If you need to gain access to washer interior, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
repairclinic.com
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Dec 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
MY WASHER FILLS UP UNTIL IT OVERFLOWS. WHAT IS
with unit unpluged,turn water on,if water come's in you have a bad inlet valve,if not than check rubber hose from outer tube to water level switch,if thy are connected than you have a bad water leaval switch.
Nov 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
water won't shut off till it overflow
it is called a pressure stut,that stop`s the water overflowing,it is on the control panel
Nov 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not stop filling up with water. second time basement flooded.
http://www.fixya.com/support/r762094-washer_overflows
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console2.gif.
repairclinic.com
Oct 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
roper top loading washer RTW444OVQ leaking when filling during washand rinse cycle what do we do
You will need to remove the washer exterior cabinet in order to sufficiently locate the source of your leak. The following steps explain how:
The pump and drain hoses connections are located in the FRONT of the washer directly under the wash tub.
The water inlet and dispenser hoses are located along the back.
To get the cabinet back on the washer, follow these steps:
1, With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
Some other things to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the are UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak. Read through everything thoroughly before beginning any repairs. I hope this information is helpful.
Aug 21, 2009 | Washing Machines
223 people viewed this tip
Top Washing Machines Experts
