Tip & How-To about Computers & Internet
10 reasons why PCs crash-You must know tip 5
5 Fatal OE exceptions and VXD errors
Fatal OE exception errors and VXD errors are often caused by video card problems.
These can often be resolved easily by reducing the resolution of the video display. Go to
* Start-Settings-Control Panel-Display-Settings
Here you should slide the screen area bar to the left. Take a look at the colour settings on the left of that window. For most desktops, high colour 16-bit depth is adequate.
If the screen freezes or you experience system lockups it might be due to the video card. Make sure it does not have a hardware conflict. Go to
* Start-Settings-Control Panel-System-Device Manager
Here, select the + beside Display Adapter. A line of text describing your video card should appear. Select it (make it blue) and press properties. Then select Resources and select each line in the window. Look for a message that says No Conflicts.
If you have video card hardware conflict, you will see it here. Be careful at this point and make a note of everything you do in case you make things worse.
The way to resolve a hardware conflict is to uncheck the Use Automatic Settings box and hit the Change Settings button. You are searching for a setting that will display a No Conflicts message.
Another useful way to resolve video problems is to go to
* Start-Settings-Control Panel-System-Performance-Graphics
Here you should move the Hardware Acceleration slider to the left. As ever, the most common cause of problems relating to graphics cards is old or faulty drivers (a driver is a small piece of software used by a computer to communicate with a device).
Look up your video card's manufacturer on the internet and search for the most recent drivers for it.
Computers & Internet Logo
fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Fatal exception error on shut down - VXD VWIN32
you need to start in safe mode and remove your video drivers. Hopefully you have a win98 disk to get the drivers off of. Remove drivers and restart, it will then recognise that the drivers are gone let it ask for drivers and let it find them automatically and install them. Then see what happens
Feb 23, 2009 | Dell Computers & Internet
86 people viewed this tip
David Payne
David Payne
