Tip & How-To about Computers & Internet
10 reasons why PCs crash-You must know tip 1
You have just been struck by the Blue Screen of Death.
1 Hardware conflict
The number one reason why Windows crashes is hardware conflict. Each hardware device communicates to other devices through an interrupt request channel (IRQ). These are supposed to be unique for each device.
For example, a printer usually connects internally on IRQ 7. The keyboard usually uses IRQ 1 and the floppy disk drive IRQ 6. Each device will try to hog a single IRQ for itself.
If there are a lot of devices, or if they are not installed properly, two of them may end up sharing the same IRQ number. When the user tries to use both devices at the same time, a crash can happen. The way to check if your computer has a hardware conflict is through the following route:
* Start-Settings-Control Panel-System-Device Manager.
Often if a device has a problem a yellow '!' appears next to its description in the Device Manager. Highlight Computer (in the Device Manager) and press Properties to see the IRQ numbers used by your computer. If the IRQ number appears twice, two devices may be using it.
Sometimes a device might share an IRQ with something described as 'IRQ holder for PCI steering'. This can be ignored. The best way to fix this problem is to remove the problem device and reinstall it.
Sometimes you may have to find more recent drivers on the internet to make the device function properly. A good resource is www.driverguide.com. If the device is a soundcard, or a modem, it can often be fixed by moving it to a different slot on the motherboard (be careful about opening your computer, as you may void the warranty).
Computers & Internet Logo
how to stop the blue screen of death
BSOD or so called, Blue of screen death occurs due to variety of reasons and once it do, you might have to force restart it to use your PC again. Old drivers, outdated windows, faulty hardware, degrading hard drive etc. are one of the top most reasons that causes bsod errors.
If you're not a pros or just a basic PC users, I'd recommend you to take your PC to any nearest computer repair shop and get it resolved there.
I'd glad to address if you've any further queries.
Feb 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
You have just been struck by the Blue Screen of Death. 1 Hardware conflict The number one reason why Windows crashes is hardware conflict. Each hardware device communicates to other devices through an interrupt request channel (IRQ). These are supposed to be unique for each device. For example, a printer usually connects internally on IRQ 7. The keyboard usually uses IRQ 1 and the floppy disk drive IRQ 6. Each device will try to hog a single IRQ for itself. If there are a lot of devices, or if they are not installed properly, two of them may end up sharing the same IRQ number. When the user tries to use both devices at the same time, a crash can happen. The way to check if your computer has a hardware conflict is through the following route: * Start-Settings-Control Panel-System-Device Manager. Often if a device has a problem a yellow '!' appears next to its description in the Device Manager. Highlight Computer (in the Device Manager) and press Properties to see the IRQ numbers used by your computer. If the IRQ number appears twice, two devices may be using it. Sometimes a device might share an IRQ with something described as 'IRQ holder for PCI steering'. This can be ignored. The best way to fix this problem is to remove the problem device and reinstall it. Sometimes you may have to find more recent drivers on the internet to make the device function properly. A good resource is www.driverguide.com. If the device is a soundcard, or a modem, it can often be fixed by moving it to a different slot on the motherboard (be careful about opening your computer, as you may void the warranty).
Mar 04, 2010 | Computers & Internet
lg cdma lxu-800 modem crashes windows vista
First Uninstall the drivers of this modem and chk if any hardware is creating a conflict with it. Next uninstall that hardware or change its slot.
Now reinstall your modem with the latest set of drivers
May 16, 2009 | Computers & Internet
78 people viewed this tip
David Payne
David Payne
