Tip & How-To about Video Game Consoles & Games
How to set up the Xbox 360 Wireless N Networking Adapter
Overview
If you connected to Xbox LIVE after October 28, 2009, a software update was installed on your Xbox 360 console to support the Xbox 360 Wireless N Networking Adapter. If the update was installed on your console, all you need to do is to configure the wireless settings. To learn how to do this, please see the following article:
908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
If you have not connected to Xbox LIVE since October 28, 2009, you will need to use the installation disc included with your Xbox 360 Wireless N Networking Adaptor to install software on your Xbox 360 console.
To install the software for a Wireless N Networking Adapter
1. If an Xbox 360 Wireless N Networking Adapter is plugged in to your console, unplug it.
2. Insert the installation disc included with the Xbox 360 Wireless N Networking Adaptor into your Xbox 360 console.
3. Turn off the console.
4. Turn the console back on.
The software update should start automatically. If the update does not start automatically, the software might already be installed.
Note If you receive a mixed media error message, please see the section titled "Mixed media error message" below.
5. When you are prompted to install the software, select Yes, update now.
6. If a network cable is plugged in to the back of your console, unplug it.
7. Once the installation is complete, plug the Xbox 360 Wireless N Networking Adaptor into the USB port on the back of your console.
For information about attaching and configuring your wireless adapter, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
8. Remove the installation disc from the disc drive.
9. Turn off your console, and then turn it on again.
If you receive a mixed media error message, auto-play might be turned off. Here’s how to turn it on:
1. On your console, go to My Xbox, and then select System Settings.
2. Select Console Settings.
3. Select Auto-Play.
4. Select Enable.5. Repeat the steps for installing the wireless adapter (above).
Next step:
For information about how to configure the wireless settings on your console, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 consoleDo not try to repair the wireless networking adapter.
Do not take your Xbox 360 console or accessories to a retailer for repair or service unless an Xbox support agent instructs you to do this.
Do not try to disassemble, service, or modify the Xbox 360 console, the power supply, or any accessories. If you do this, you might put yourself at risk of serious injury or death from electric shock or fire. For your own safety, such actions will void your warranty.
Video Game Consoles & Games Logo
What does status code: 3f4a 3f4a 1601 0300 c800 0036 mean?
Error C800-0036 occurs when downloading an update to your Xbox 360 console. This may mean that there's a lock on your Xbox Live account. If your Xbox 360 console has been tampered with or modified, it can no longer connect to Xbox Live, install software updates or play new games that require a console software update.
Mar 17, 2016 | Video Game Consoles & Games
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
i try to play movies and music off flashdrive and it says i have to do a media update how do i do that ihave a new Xbox slim 250gb
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update the console software.
Sep 26, 2011 | Microsoft Xbox 360 Console
how to update your xbox360
  1. Connect your Xbox 360 console to the Internet. To learn how, please see Connecting to Xbox LIVE.
If you cannot connect your Xbox 360 console to the Internet, you can copy the console update from your computer to a USB flash drive and then install it on the console.
Note: The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file on your computer.
  4. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  5. Copy the contents of the .zip file to the root directory of your flash drive.
  6. Unplug the USB flash drive from your computer.
  7. Plug the flash drive into a USB port on your Xbox 360 console.
  8. Restart the console.
  9. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
You can update your Xbox 360 console software by downloading the update to your computer from Xbox.com, burning the update to a CD or DVD, and then installing the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file on your computer.
  3. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using an earlier version of Microsoft Windows, you need to use a special software program to unzip the file (for example, WinZip).
  4. Insert a blank, writeable CD or DVD into your computer.
  5. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  6. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
  7. Restart the console.
  8. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Feb 04, 2011 | Microsoft Xbox 360 Console
How can I update my xbox 360 system
To update on Xbox LIVE:
  1. Connect your Xbox 360 console to the internet. If your console is not connected already, see Connect to Xbox LIVE.
  4. Select Wired Network or the name of your wireless network if you are prompted to do so.
  6. Select Yes if you are prompted to update console software.
Copy the Update to a USB Flash Drive If you don't have an Xbox LIVE account or have a slow Internet connection, using a USB flash drive is a good option.
Update using a USB flash drive:
  1. Connect your USB flash drive to a USB port on your computer.
  2. Click here to begin downloading the update folder. Save it as "$SystemUpdate9199.zip" anywhere on your computer.
  3. Unzip the File.
  4. Copy the contents from the unzipped folder onto the root of your flash drive.
  5. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console. If your console is on, turn it off, then back on. The update program will start automatically.
  6. Select Yes when you are prompted to update the console software.
Dec 15, 2010 | Microsoft Xbox 360 Console
318 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
