Tip & How-To about Video Game Consoles & Games
Sony PS3 Hard Drive Corrupted or Asking for Restore
A Hard Drive error can be a common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Please note: Steps 8 and 9 involve erasing data from your Hard Drive. Therefore if at all possible please try to back up your data before commencing this procedure. You can do this through 'System Settings - Backup Utility' Follow the instructions given in this menu to back up information to an external storage device such as a USB Pen.
To begin the process of troubleshooting and resolving your Hard Drive error you must first put the unit into Safe Mode. Follow these steps carefully;
1) Turn off the PS3 by holding the power button on the front of the unit till it turns red.
2) Hold the power button until you hear the unit beep three times. This will take 15 to 20 seconds.
3) The unit will power off on the third beep and power light will turn red again.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this release the power button.
5) You will see a message onscreen telling you to "Connect a controller using USB and then press the PS button".
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode.
7) Restore File System. From this point select "Restore File System" on the menu. The PS3 will attempt to repair damaged files on the hard drive. If this does not work move to step 8.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase certain information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
9) Restore PS3 System. Again enter Safe Mode and select "Restore PS3 System". This will restore all defaults and completely formats the drive. Be aware this mode will erase all information from the hard drive.
If everyone of these steps fail and the PS3 is still showing symptoms of hard drive error you can be certain that the hard drive has failed and it will need to be replaced. However in a majority of cases these steps will resolve the issue.
Video Game Consoles & Games Logo
it says that the hard disks sysem corrupted
Hi. This is an unfortunate occurence . The actual hard disk has corrupt clusters at this time. The only recourse will be to replace the damaged hard disk. With that said, if you have recently updated your firmware, this may cause this message as well, due to a corrupt firmware update pack. If you have not recently updated your units firmware, the necessary actions are to have the damaged hard disk replaced by a certified sony repair depot. This repair may be free of charge if the unit was purchased within a six month period,but if not, you may be charged a shipping fee, if any. contact sony asap for your repair ticket.
Oct 09, 2011 | Sony Playstation 3 (PS3) Console
hard disk drive is corrupted
This is a common enough error on the PS3. It can sometimes be resolved without resorting to replacing the hard drive. For a walkthrough on all the possible solutions to this particular error please see this FixYa Tip.
Thanks for using FixYa.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
hard disk corrupt , goes through process but keeps coming back to "hard disk is corrupt"
This is a common enough error on the PS3. If you are lucky it can sometimes be resolved without resorting to replacing the hard drive. For a walkthrough on all the possible solutions to this particular error please see this FixYa Tip.
634 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
