Tip & How-To about Video Game Consoles & Games
Wii remote buttons are sticky or stuck down
Try cleaning the buttons of the nintendo Wii Remote using the cleaning instructions below, being sure to follow the directions carefully.
    What you will need:
  • 1 clean toothbrush (no toothpaste on it)
  • 1 cup of warm tap water
  • 1 paper towel
    Instructions:
  1. Remove the batteries from the Wii Remote.
  2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the Wii Remote in any type of liquid.
  3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the Wii Remote around the buttons.
  4. Work the bristles down around the sides of the buttons.
  5. After cleaning the Wii Remote, dry it off with a paper towel.
  6. Let the Wii Remote air dry with the buttons facing down for at least a couple of hours.
  7. Test the Wii Remote for proper response.
  8. Repeat the steps if necessary.
If the buttons are still sticky after cleaning, the Wii Remote will need to be replaced. Our experience shows that this type of problem is usually caused by physical damage and not covered under Nintendo's warranty. You can purchase a replacement at retail stores that sell Nintendo products.
Video Game Consoles & Games Logo
Ok, well me and brother want to play Wii. But we only have one remote, And that remote wont turn on. We are getting like so mad. We've changed the batteries like 5 different times, we've tried Syning it, but its still not working.. What do i do?
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
or if the remote lights up briefly than goes out try this
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance. [nintendos help line]
i hope this helps you and please vote for me
Dec 06, 2010 | Nintendo Wii Remote Controller
My wii is working fine, but the controllers aren't connecting, what should I do?
Did you sync them?? Check the following Nintendo website with a HOWTO on syncing controllers:
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out)
    Try these steps!
CLICK HERE FOR MORE INFORMATION FROM NINTENDO'S WEBSITE
Aug 17, 2010 | Nintendo Wii Console
unable to setup second hand control , now doesn't recognize either
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response. If the problem is not solved, please follow the rest of the instructions on this page. For all Wii Remote issues: If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info). Make sure you are using fresh batteries in the Wii Remote. The Wii Remote Controller should be used between 3 to 10 feet from the TV. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common: Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, Try these steps! Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes: With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture). When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4). This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Feb 22, 2010 | Nintendo Wii Console
actions are reversed
Wii Remote Troubleshooting red_circle_arrow.gif Important Safety Information for Playing Wii red_circle_arrow.gif Wii Remote Wrist Strap Replacement Information Quick tip: Cursor (hand) or character movement not responding properly?
If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    Tilt Problems
    1. Check the motion sensor functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
    2. Try placing the Wii Remote in a neutral position by resting it on a flat surface during game play. If the character or cursor still tilts on its own, there is a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
    ^ Back to Top
Oct 30, 2009 | Nintendo Wii Console
wii remote keeps beeping and not working
try this! I found it on Nintendo.com under support:
      Try these steps!
  • Sep 01, 2008 | Nintendo Wii Console
    466 people viewed this tip
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
