Tip & How-To about Video Game Consoles & Games
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
Video Game Consoles & Games Logo
Alba 32 inch LCD TV develops bright wash during use, with any light images on screen for more than a second producing a vertical banner which spans the height of the screen. Prolonged viewing also reveals a grid of dark spots, presumably some part of the control or component systems of the TV. Seemingly, this problem is lessened when viewing certain video files, presumably in relation to the images changing more frequently during these files' playback. Using games such as Halo 4, with a constant HUD on screen, the stretched banner from these objects renders the screen effectively white-washed, ruining the experience. A brief respite from the brightness can be achieved by putting the TV on standby, waiting a few seconds and then bringing the screen back on, however within a few seconds the ghosts appear once again. TV is <2 years old, predominantly used to game, stream video from services such as Netflix etc on an Xbox 360. Input is via component cable, using an HDMI does not change the issue. Have attempted changing contrast, enabling the "game mode" (whatever that would do) and even giving the system large breaks - none of these have produced more than short-term results. Any advice on how to potentially fix this issue (new components etc) would be greatly appreciated. I can't really afford a new TV at present, so if I can repair this one I'd be much happier.
This is a too long description. Please try to concise this, and re-post it.
Oct 23, 2013 | Televison & Video
I bought Super Mario Bros. 3 from the Wii Shop Channel, but when I attempt the play the game the screen just goes black and all that's left are the words "invalid format." Also, the TV is an LG. What can I do to fix this invalid format problem so I can play the game? Another question, if it is a complicated process to fix is there any way I can get a refund for my purchase?
Hello.
Here is what it says in Nintendo Wii SHop:
Some newer-model televisions may have difficulty properly displaying some Virtual Console games downloaded from the Wii Shop Channel. If you are experiencing problems (such as a blank screen but you can hear the game's audio), please try the following:
    Try changing the way your Wii console is connected to your television. For instance:
    • If the Wii console is connected to a VCR or cable box, try connecting the Wii directly to the TV (how to).
    • If the Wii console is connected to the TV directly, try connecting it to a VCR (how to).
    • If possible, try connecting to another TV.
    If any of the above are successful, it is recommended you use the connection that works. If the Virtual Console game still did not display properly after trying different connection types, please call 1-800-255-3700 to discuss available options.
Aug 03, 2011 | Nintendo Wii Console
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 21, 2009 | Dell Latitude D600 Notebook
Some Virtual Console games don't work!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Nov 18, 2008 | Nintendo Wii Console
249 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
