Tip & How-To about Vacuums
Vac's that just stop
Meany time's i find high priced vac's out by the road,4 the trash man to pickup. each time i c that i stop & pick it up.
about 90%of the vac's just need 1or2 thing to work.
i have never seen ny brand vac that didnt come with a red reset butten.
that seams to do it,but being i just picked it up i cheack 3 things.
the belt &i unstop no matter what.
belt reset switch &clean the dirt out. that allways helps.
but some times i c dead 1s.
thanks
life's handy man
Vacuums Logo
miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Dyson I sucked a towel up by mistake an it started smoking an burning smell turned off power what damage will I av caused
As a general rule when you pick up a sock or towel or anything laying on the floor that is too big for the vac to handle, it generally stops the brush roll, which in turn stops the belt and that in turn makes the belt burn in two in about 20 seconds, if you don't catch it in time. Now on most vacuums this isn't a major repair. Most folks, with a modicum of mechanical knowledge can change a belt on about 90% of the upright vac's around, but the Dyson's aren't in that 90%, they're in the ten % that make it incredibly difficult to change a simple belt. You'll need to take it to your friendly neighborhood vac repair shop and have them put on a new belt, depending on which belt that broke. Have them give you an estimate first. You may be surprised at what it costs to have a belt changed, if it's the one that's on the clutch assembly.
Nov 10, 2013 | Vacuums
need to find repair man
<P>Try this web site. They do a fixed price repair and service. Pick up and return all for £89.00. Take into account a new hose ans trigger cost around £74.00 plus postage, it seems a fair price.</P><P>&nbsp;</P><P><A href="http://callde.co.uk/polti_authorised_repair_agent.asp">http://callde.co.uk/polti_authorised_repair_agent.asp</A></P>
Jun 25, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Does not pick up water.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=628888
Posted by lazybug002 on May 28, 2008
What can I do and what part do I need to replace? I have taken it apart and clean it but still won't pickup the water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. It sounds to me that you may have a clog or an obstruction or the channel to the suction motor per say might be broken and is not creating the suction needed to pickup the water to the recovery tank. So check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
172 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
