Tip & How-To about Computers & Internet
Laptop/Notebook Hard Drive Replacement.....
You may have been led to believe, or assume that some companies use proprietary hard disc drives in their Notebook PCs...Not the case at all!!!
Most Notebook PCs (laptops) use *
Ultra ATA 2.5" internal Hard Drives (HDD)
Even Dell, Gateway, Sony, etc..
*Note that Ultra ATA is also known as ATA-6.
So don't pay extra for a so-called proprietary type hard drive,
Just go online and find a compatible Drive to replace it.
Also, keep in mind that although your original HD might be a 4500 rpm
speed HD, You can use a faster one, like a 5400 RPM. (a 7200 rpm drive
will consume a little more power than you want and can tend to increase temperatures, so be aware).
I just thought everyone who doesn't know that, to know that.
I'll be posting more tips/tricks/advice whenever something comes to mind.
....There ya have it!
Computers & Internet Logo
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
LaCie Rikiki stops working. The led does not blink.
This kind of fault is usually the case to drive interface. You can remove the drive and try to plug it into you computer using the IDE or SATA cables your drive needs. You will then be able to tell if it is your drive or the case.
Jul 12, 2013 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
pc won't let me reformat it i've no disc because it's built in on the hard drive please help
If you want to reformat a harddrive on your current computer, you need to remove the drive and plug it in as a secondary drive on another computer. Then formatting is easy.
Alternatively, you can use your operating system installation disk and format before re-installing your OS.
Mar 09, 2010 | HP Computers & Internet
I have a Western Digital MyBook 250gb that the hard drive died in. I took the case apart and installed an old 20gb drive in it, so I know the case is good. I am trying to find the largest hard drive that will work in this case '' WD25001032-001 ''. The S/N is WCANK9568361. I am assuming that all the USB/IDE controllers are the same for the whole product line. I am aware that some of these drives may be SATA but I am only concerned with the IDE specs. With that information, I can maximize the output of the case.
you should be able to install any manufactures HDD , if yours is
a SATA then you must put an SATA in as goers the same for an
ATA so whatever company you choose you need to obtain that
companies formatting tool utility , it is true that seatools Seagate
and Maxblast Maxtor will work with other companies , and the
best of those two would be Maxblast in my opinion it has the
ease of use , also you should be able to use any HDD no matter
the size , and remember to NEVER install an OS on your static
external HDD it will only cause the HDD to become corrupt and
enable it to contract viruses , I use 1 internal 500 and 1 external
250 backed by 1 non-powered (not used till needed) 250, its the
only way to really be protected in case something happens to
the storage drive , age and use are the number one reasons
for HDD failure and in some cases external HDD closers come with some kind of proprietary software such as one touch back
up , which you can archive to hidden in the folder properties
or simply erase , I never trust auto backing , I do all my backups
manually .
Jan 19, 2010 | Western Digital 250GB MyBook External USB...
174 people viewed this tip
David Payne
David Payne
