Tip & How-To about Car Audio & Video
How to watch pyle plts76u car dvd whilst driving and how to bypass parking brake to watch dvd
If you want to use your dvd player whilst driving then i will tell you the best way to go about doing this but please read these warnings first.
WARNINGS.
1. any work you do at your own risk
2. it highly illegal to use any dvd or telly whilst driving
3. if caught using dvd whilst driving you will get a big fine and points on your license for driving whilst distracted.
4. if you have an accident whilst the dvd player is driving you wont be insured and you will be liable and charged with dangerous and reckless driving.
5. any short due to work carried out can cause you to destroy the stereo and in some cases cars have been set on fire, so if you are unsure what you are doing then please dont go ahead with this work as you could end up in a right mess.
Ok now the warnings are out of the way.
I take it you dont want to watch the dvd whilst driving but a passenger does i dont reccomend this work be carried out if the driver is planning on watching the dvd whilst driving, its not worth the risk its just to dangerous.
How To Bypass The Parking Brake To Watch DVDs'
the best way of doing this would be to get hold of the instruction manual to install this stereo you might get this off the net but if not you can contact the makers and they will be able to send you one for free, just the cost of postage to pay.
Now to actually bypass the parking brake witch dont let you play dvd whilst driving what you need to do is locate the wire that goes to the parking brake now this wire should be a brown wire unless somebody has re wired the stereo to fit other cars, once you are sure you have located the correct parking wire thats brown you then need to remove this wire from the parking brake. Now you need to earth this wire out to any metal on the car and secure it to that metal part this should then bypass the parking brake system for you.
You do this at your own risk you can destroy the stereo and in some cases set fire to the car so if you have never done this type of work before then please leave this to somebody who knows what they are doing.
Take your time, make sure you have the correct earth wire any other wire and you will short the stereo out destroying the stereo and possibly your car, so be warned.
Car Audio & Video Logo
I just installed the unit, reset it twice, and the DVD screen is not working, and is saying "WARNING: Please Stop Watch Video" What does that mean?
I do not know this specific unit, but it sounds like a safety device built into the unit so you cant watch the screen whilst driving.. it may be that you have ommitted a sensor wire or got a sensor wire reversed.
Re-check all your wiring and make sure that the ignition live and the battery live wires have not been reversed...
Sep 01, 2010 | BOSS AUDIO SYSTEMS BV9155B Car Video...
wont play while im driving
hi, the problem with these dvd players is they have a safety feature that is connected to the parking brake and this means once the parking brake is taken off the dvd player then will stop.
PLEASE READ THIS.
you do this at your own risk keep reading and ill tell you how to best go about doing what you want, if you get caught using dvd whilst driving you will get a big fine and points on your license ok
Its not advised you use the dvd player whilst driving so i cant reccomend you doing any work to it yourself.
If say you wanted it working whilst driving so that a passenger could watch it then their is a way around getting this working whilst driving, if you get caught using this whilst driving you will get a fine and possible points on your license as your not supposed to have any working dvd in the front of the car whilst moving as you will get distracted.
Now the problem you have of getting this working whilst driving is that your going to need to get hold of the instructions that was used to fit the stereo as this will then tell you witch wire is connected to the parking brake once you have this you then need to bypass this wire by either earthing it out if its an earth wire or if its a possitive wire then you would need to wire this into a permanent live feed like the direct live feed into the stereo.
Now you could take the stereo out and see where all the wires go to doing this would then show you witch wire goes to the parking brake you would then need to test this wire to find out if its an earth or live type of wire, to do this you would need to get hold of a multimeter one of these will tell you if its a live or not.
If you find the wire thats connected to the parking brake you should be able to tell if its live or earth by looking at how its connected to the parking brake if its just earthed out then it will be an earth but if it goes to a switch on the parking brake then its more than likely a live wire.
On asking someone about your make and model of stereo it seems the parking brake wire is a brown wire and you then need to remove this wire from the parking brake and just earth it out on any part of the metal of your car this should then let you watch dvd whilst driving.
remember you do this at your own risk its not advisable to use a dvd whilst driving and you are breaking the law by doing this so i cant encourage you to go ahead with this type of work, if you really want to do this then take your time and double check you have the wires correct ok
its not worth taking the risk by just guessing as this could blow your stereo up leaving it scrap so its best this wire is tested.
If you are unsure what you are doing then please dont mess with it as any short will destroy the stereo and it has been known to cause several car fires so if it is a live make sure you use an in line fuse.
It would be a lot safer if you went to the makers web site and see if they have an instruction manual on their if they havent then they will send you one out for free this would be the best option for you.
If you really are unsure and have never wires stereos in before then leave it to someone who knows what their doing they may question why you want it working whilst driving but just tell them you drive a kid around who watches it to stop him being car sick, the sob story usually works
Let me know how you get on or if you need further assistance
Mar 03, 2010 | Pyle PLTS76U Car DVD Player
can someone please tell me how to watch a dvd whilst driving on my eonon e1025
wire it up to the ground wire the cable thats says parking or sum thing like that this it the orange wire
Dec 28, 2009 | Car Audio & Video
hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
durabrand 8.5 dvd player
Is it the correct type of disc? Whilst these devices will play almost all 'commercial' disks In many cases 'burned disks' Cumputer Data disks and audio disks are a No No The manual/packaging will tell you which. You could try a Lazer cleaner disk. Failing that it looks as if the device is failing and needs replacing - I doubt if there is a repair option.
May 23, 2007 | Durabrand DUR7 Portable DVD Player
809 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
