Tip & How-To about Office Equipment & Supplies
I get cartridge error on my HP printer.
Hi.
To start test using a different cartridge set. The problem may have been caused by defective cartridges.
Also reinstall the driver software, even if it is rather unlikely that this is a software issue, that is a necessary step in troubleshooting.
After that try powercycling the printer, and do the following cartridge maintenance:
  1. Check for fragments of paper stuck inside the printer or on the printer feeding tray.
  2. Remove printer cartridges.the metal plate contact in the ink carriage using isopropyl alcohol and cotton.
  3. Clean
  4. Put back printer cartridges.
  5. Turn off printer.
  6. Disconnect printer power cable.
  7. Restart computer.
  8. Empty printer cue on computer.
  9. Connect back and start the printer.
Regards
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to check' old cartriges. Advise.
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Sep 14, 2010 | HP Office Equipment & Supplies
I just refilled my printer cartridge and it keeps telling me unsupported cartridge. I have not had this happen in the past, help please
Hi Glenda
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Jeeth
Sep 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
error message "change cartridge invalid refill" the printer wont print anymore
Apr 27, 2009 | Office Equipment & Supplies
Excessive Yellow ink use
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
141 people viewed this tip
k24674
jasbo
jasbo
