Tip & How-To about Cycling
Bike Maintenance Tips
  • Regularly check tyre condition and air pressure. Optimum air pressure in the tyres of the bike is important for maximum road grip, stability, riding comfort and longevity of the tyres.
  • While under-inflated tyres wear unevenly, adversely affect handling, and more likely to fail from being overheated, over inflated tyres make the motorcycle ride more harshly, and more prone to damage from surface hazards, and wear unevenly.
  • Check your tyres for cuts and scrapes on your tires, which could cause a blowout. Also check the tyre treads once a week and have the wheels balanced and the alignment checked if the wear is uneven.
  • Engine oil plays an important role in ensuring smooth operation and maintenance of the bike and maintaining a correct engine oil level is important. Check engine oil level each day before operating the two–wheeler. Oil level should be between upper and lower marks. Top up engine oil if required. Check for oil leakage.
  • Clean the two-wheeler body surface regularly to maintain the surface finish. Before cleaning the motorcycle, ensure that the ignition switch unit, H.T. Coil and silencer are covered using plastic sheets.
  • Clean the motorcycle using low-pressure water. All painted surfaces should be washed only with water, as kerosene or detergent will damage the paint.
  • The motorcycle battery needs periodical maintenance to ensure a long and trouble free life. Check the electrolyte level against the top and bottom markings on the battery shell. Always top up with distilled water whenever required.
  • Check for any leakage from battery. It should be clean and free from any leakages. In case of non-use of motorcycle, battery should be kept fully charged and electrolyte level should be at Top mark.
  • Clean spark plug regularly. Every 750 km for two-stroke bike and every 1,500 km for four-stroke bike. Clean spark points (electrodes) with emery paper.
  • Keep carburettor clean. Every 1500 km, clean out the carburettor float chamber and other parts. Clean jets by forcing compressed air through them.
  • Keep both brakes properly spaced. Keeping them too tight (too urgent), or too loose (too late) is dangerous. Brakes should be tightened as per the rider’s personal style and requirement.
  • Check cables regularly for kinks, bends and frayed ends. Especially check ends. If one or more strands appear broken, replace immediately.
  • Always ensure that the tax is paid and Insurance cover (Insurance policy) is within validity period. Keep Tax Receipt and Insurance policy at home and keep xerox copy in bike.
  • Posted by on
    Cycling Logo
    Is their any concerns on my 450 yfz 06 wen riding in the rain
    Don't know what you mean, are you going to be riding it on the road? Only concern I'd have with a MX bike in the wet is riding with nobbly tyres, they don't have much grip on road surfaces but perfect for muddy conditions.
    Feb 03, 2015 | Motorcycles
    Is it recommendable to lower the tyre pressure of a touring bike from 2.7MPa to 1.3MPa for riding gravel roads?
    Well, after you're pass the gravel road, is there a way to replace the air once you're back on pavement?
    Jan 01, 2014 | 2008 Honda XL 700 V Transalp
    What are the recommended tyre pressures please?
    Hiya there,
    Right then, not exactly the easiest or most straightforward of questions, but as you are a motorcycle rider, this should be easier for you to understand as you have a better idea about the road; than most peoples' perception.
    So, tyre pressure? Well of course there is a recommended baseine, but there is also fluctuations you have to allow for; these variables take the form of wether you are uing the bike in warm, hot, cold, wet or dry condtitions; and all of which your tyre pressure is based and adjusted by. Heat, cold and certain road conditions means you will have to make allowances for the pressures within your tyres. Also if you have a lower pressure in your tyre and you ride on a hot day, your tyre pressure will increase.There is a problem with this, if you already have high pressure within your tyres and you decide to go out for a heavy-duty long motorcycle ride. This has a good possibility that you will get a blowout (where the tyre fails dueto extreme high temperature within the tyre walls and the pressure i too much for the compound to take, and as a result; it explodes).
    FYG Michelin's website recommends 2.2 Bar Front and 2.4 Bar Rear for all the tyres recommended for use on all the ST series (2/3/4 & 4s) but these pressures only apply to their tyres as the construction is considerably different to some other manufacturers particularly with regard to weight.
    Too high pressure will cause premature wear on the centre and reduced grip.
    (This may show itself as quicker response due to lack of resistance to turning input)
    Lower pressures will cause less wear on the centre and possibly less effective grip in the wet in road conditions due to the tread closing up but can be used to compensate for the higher temperatures developed on track (track days etc)
    The best thing here to do is (carefully) wheely on down to Ducati, and get them to tell you; or consult the owners manual, and also the guide on what the tyre company (who supply yours) have to say about this.
    Somewhere in the region of 30-32 Psi on the front and 30-35 Psi on the rear should be about right. Remember, hot conditions, slightly lesser, cold, slightly more.
    I hope this is the fixya for you and I look forward to hearing how you get on.
    Yours sincerely
    Oz
    P.S.
    Please do leave feedback on this, as here there are a lot of questions writing in about tyre pressures and Ducati are a common bike that do attract questions. Your feedback is greatly appreciated as so it too can assist fellow riders in maintaining their pride and joy; and keep them safe for many years.
    Thanks again and stay safe on those open roads!!
    Mar 08, 2010 | 2003 Ducati ST4
    239 people viewed this tip
    Top Cycling Experts
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
