Tip & How-To about Microsoft Windows XP Professional
How to solve NTLDR is missing issue in windows XP
Using Windows recovery console.
The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility.
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged:
Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed.
1: Insert the Windows XP bootable CD into the computer.
2: When prompted to press any key to boot from the CD, press any key.
3: Once in the Windows XP setup menu press the "R" key to repair Windows.
4: Log into your Windows installation by pressing the "1" key(most of the cases it will be "1" only) and pressing enter.
5: You will then be prompted for your administrator password, enter that password.
6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
COPY D:I386NTDETECT.COM C:
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Microsoft Windows XP Professional Logo
Installed a ASUS A8N5X motherboard and it go through bios and stops and then it tells me that NTLDR is missing . How do I fix this Thank you.
How to solve NTLDR is missing in windows XP issue
Using Windows recovery console. The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility. This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed. 1: Insert the Windows XP bootable CD into the computer. 2: When prompted to press any key to boot from the CD, press any key.
5: You will then be prompted for your administrator password, enter that password. 6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
Ref: http://www.soluzia.net/ntldr-is-missing.php
Jul 01, 2010 | Generic Memory INSTALL CPU AND MEMORY ON...
my friend has a HP Pavilion 533w and when we turn it on it goes threw the loading screens and then to a black screen and nothing happens you can move the mouse and see the pointer but nothing happens still. what can we do
It is possible that the file Lsass.exe has become damaged or is not properly linked to the other files in the security system. Reset this file by using the following steps:
1. Turn on the PC and press the F8 key repeatedly when the first screen appears.
The Windows advanced options menu appears.
2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
3. Select Microsoft Windows Recovery Console .
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
6. Press Enter , do one the following:
  • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
  • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered.
Dec 26, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
labtop wont boot...only has a blinking curser
Dec 26, 2008 | Computers & Internet
1,159 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
