Tip & How-To about Microsoft Windows Vista Ultimate Edition
Repairing Windows Vista using bootrec.exe
Bootrec.exe tool can be used in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
/FixMbr Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs Use this option when there are Windows Vista installations that the Boot Manager menu does not list.
/RebuildBcd Use this option when you must completely rebuild the BCD.
Note: It will work with all windows Vista versions
Microsoft Windows Vista Ultimate Edition Logo
presario cq5210y orange light continuous flashing, why?
You didnt give much info more info gets better answers.. but if your PC wont turn on and the light is flashing amber in color it could indicate a power supply failure.
Mar 16, 2012 | Compaq Presario CQ5210y PC Desktop
acer aspire 5515 reading bootmgr is missing. i've done alt ctrl dlt and f2 reading the same thing.can some one help mr to get my laptop to reboot please? thanks.....
We wish you a merry Christmas and a happy new year.
To resolve this problem, use the following methods in the order in which they are presented.
Method 1: Repair the BCD store by using the Startup Repair option You can use the Startup Repair option in the Windows Recovery Environment to repair the BCD store. To do this, follow these steps:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Startup Repair. 7. Restart the computer. Method 2: Rebuild the BCD store by using the Bootrec.exe tool If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
You can also follow the video.
Hope this helps.
Cheers!!
Dec 31, 2010 | Acer Computers & Internet
bootmgr is missing
Find your recovery CD and use that to restore the laptop to Factory default settings
Oct 26, 2009 | Computers & Internet
BOOT MGR MISSING
Rebuild the BCD store by using the Bootrec.exe tool If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps: 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Sep 08, 2009 | Dell Inspiron 1525 Laptop
touchsmart tx2-1025dx bootmgr missin
Please go to the link below to know how to run destructive recovery. PLEASE NOTE THAT YOU WILL LOOSE ALL DATA IF YOU RUN THIS.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809678&lc=en&dlc=en&cc=us&product=3860702&rule=27693&lang=en#RecoverOS
If you do not want to loose data, You will need a Vista installation DVD to resolve this issue. You may borrow it from someone.
Following are the steps:
Method 1:
Method 2:
7. Type Bootrec /RebuildBcd, and then press ENTER.� If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes. A confirmation message appears that indicates the entry was added successfully.
� If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bootrec /rebuildbcd
Method 3:
Rebuild the BCD store manually by using the Bcdedit.exe tool
If the previous method does not resolve the problem, you can rebuild the BCD store manually by using the Bcdedit.exe tool in the Windows Recovery Environment. To do this, follow these steps:
7. Type the following command, and then press ENTER:
cd /d Partition:\Windows\System32
Note Partition represents the letter of the partition on which Windows Vista is installed. Typically, this is partition C.
8. Type the following command, and then press ENTER:
bcdedit /enum all
In the Windows Boot Loader section of the output from this command, note the GUID that is listed for resumeobject. You will use this GUID later.
9. Type the following command, and then press ENTER:
bcdedit -create {bootmgr} -d 'Description'
Note Description represents the description for the new entry.
10. Type the following command, and then press ENTER:
bcdedit -set {bootmgr} device partition=Partition:
Note Partition represents the letter of the partition. Typically, the letter is C.
11. Type the following command, and then press ENTER:
bcdedit /displayorder {GUID}
Note GUID represents the GUID that you obtained in step 8.
12. Type the following command, and then press ENTER:
bcdedit /default {GUID}
13. Type the following command, and then press ENTER:
bcdedit /timeout Value
Note Value represents the time in seconds before the Windows Boot Manager selects the default entry that you created in step 12.
14. Restart the computer.
**Please rate the solution**
Mar 24, 2009 | HP TouchSmart tx2z
1,318 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
