Tip & How-To about Microsoft Windows Vista Ultimate Edition
How to troubleshoot "Lsass.exe-System error The end point format is invalid" issue in vista
To solve this issue, restart your computer and go to Safe Mode.
To go to Safe Mode,keep pressing F8 key when the computer starts. Then, when the computer is in Safe Mode, there you have to do some registry edit.
"Warning : Serious problems might occur if you modify the registry incorrectly by using Registry editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk" For that login as administrator or with admin privilages.
1.Click Start, click Run, type regedit, and then click OK.
2.In Registry Editor, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrent controlsetControlSession managerMemory management
3.On the Edit menu, point to New, and then click DWORD value.
4.Type SystemPages, and then press ENTER.
5.On the Edit menu, click Modify.
6.Click Decimal, type 31000, and then click OK.
7.Quit Registry Editor and restart your pc
Microsoft Windows Vista Ultimate Edition Logo
Startup Repair cannot repair this computer automatically
Try booting into the Safe Mode and check if the issue persists.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words Safe Mode appear in the corners of your monitor to identify which Windows mode you're using.
1. Restart your computer. Click the Start button, click the arrow next to the Shut Down button, and then click Restart.
2. Do one of the following:
· If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
· If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter.
4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
To know more information on how to boot into Safe mode visit the following link:
Start your computer in safe mode
http://windows.microsoft.com/en-us/windows7/Start-your-computer-in-safe-mode
Method 2: Also scan the Computer for error using chkdsk command in the Command Prompt from the System Recovery Options Menu.
To open the System Recovery Options menu on your computer
1.Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
2.Do one of the following:
•If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
•If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3.On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4.Select a keyboard layout, and then click Next.
5.On the System Recovery Options menu, click a tool(Command Prompt) to open it.
6. At the Command Prompt, type: chkdsk /r . Press Enter.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
Apr 03, 2014 | Microsoft Computers & Internet
won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
how do i start up in safe mode (i have a spyware virus)
Restart your computer and as your computer restarts but before Windows launches, press F8. Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
Hope this helps.
Dec 29, 2010 | Computers & Internet
no programs, no buttons work, mouse works, starts but thats it
Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
Please leave your feedback if issue was solved
May 27, 2009 | Dell Inspiron B130 Notebook
real player crashes
Hi
Do the following steps in order to solve this issues. All you need is to restart the system in safe mode by the hitting F8 key as soon as you press the power button.
Start tapping the F8 key and you can see advance option screen. Choose safe mode and hit enter.
Once you enter safe mode
Right click on c:\ and go to properties and then go to tools -> error checking -> check both the dialogue box and then click ok. You get an option which says do you wann schedule the checkdisk the next time the system starts -> click ok
Restart the computer and allow the checkdisk to execute in 5 stages your system restarts on its own which is normal. Your all application problems are solved.
Jan 07, 2009 | Computers & Internet
870 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
