Tip & How-To about Computers & Internet
Change Internet Explorer Title Bar Text
To change the text in the title bar of Internet Explorer, follow the below mentioned steps.
1) Goto - [Start] - [Run] - [Regedit]
2) Guide to the given Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
3) Modify/Create the Value Name [Window Title] according to the Value Data listed below.
Data Type: REG_SZ [String Value] // Value Name: Window Title
Value Data: [Enter The Text Desired In Title Bar]
4) Exit Registry and Reboot
Regards,
Shrey
Computers & Internet Logo
How to Correct the Error KB927917
There are a couple of things you can try to fix this. I think you must likely will just need to run IE8 with 'compatibility view' enabled (see below).
Method 1
I would suggest you to run the website in Compatibility mode and check whether you are able to access the website. Follow the steps mentioned below to turn Compatibility View on or off,
a. Click the Compatibility View button that is present near the address bar, or add the website to the Compatibility list.
Follow the steps mentioned below to add the website in compatibility list.
a. Open Internet Explorer by clicking the Start button. In the search box, type Internet Explorer, and then, in the list of results, click Internet Explorer.
b. Click the Tools button, and then click Compatibility View.
For further reference follow the article mentioned below.
Why don't some websites display correctly in Internet Explorer?
http://windows.microsoft.com/en-US/windo...
Method 2
I would suggest you to Reset internet explorer and check, whether the issue persists. Follow the steps mentioned in the article given below.
Reset Internet Explorer settings
Hope one of these works!
Feb 04, 2011 | Microsoft Internet Explorer 8
how will solved script error "c:\windows\systems32\rahul"svirusprotection.vbe"
Rahul'sVirusprotection.vbe is a virus.
Follow the given steps to get rid of it
1) In Windows Explorer
Go to Tools -- Folder Options --View
Show hidden files and folders ---check this one
Hide prorected operation system file --Uncheck this one
2) Go to System Directoty ex: (C:\windows\ system32)
find this file "Rahul'sVirusprotection.vbe" and delete this one,
if u can't do that following the below steps
1)open the TaskManager(press control+Shift+Escapte key) then in
process Tab find ths Process "wscript.exe" and delete this one
or
2) using Unlocker 1.8.8.exe (search in Google site) for delete this
file
3) Type Regedit.exe into RUN Command
HKEY_CURRENT_USER\ SOFTWARE\ MICROSOFT\ INTERNET EXPLORER\MAIN
[Window Title = ""]
[Start Page = "www.google.com"]
HKEY_LOCAL_MACHINE\SOFTWARE\ MICROSOFT\Windows NT\ CurrentVersion
\Winlogon
[Userninit = "C:WINDOWS\system32\userinit.exe"]
Dec 22, 2010 | Computers & Internet
presence of rahul the hacker in my web page with tittle bar
Try this
[Start]
[Run]
[Regedit]
Hope It Solved Your Problem
Good Day
Apr 17, 2009 | Microsoft Windows XP Professional With...
158 people viewed this tip
David Payne
David Payne
