Tip & How-To about Microsoft Windows Vista Ultimate Edition
How to back up the registry in Windows Vista
1.Click Start, type systempropertiesprotection in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
2.Wait for Windows to search for available disks and most recent restore points. In the System Properties dialog box, on the System Protection tab, click Create,
3.Type a name for the restore point and then click Create
4.After the restore point has been created successfully, click OK two times.
Note: If System Restore is turned off, click to select the local disk, click Apply and then click Create.
Microsoft Windows Vista Ultimate Edition Logo
run time error 75 path file access error
You should try to clean boot the system to see if the problem clears up.
Follow the steps below to place your computer in "clean boot"
  • Click the Start on your Desktop
  • Type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  • On the General tab, click Selective Startup.
  • Under Selective Startup, click to clear the Load Startup Items check box.
  • Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  • Click OK.
When you are prompted, click Restart.
When the desktop loads, test again and see if you still receive the error.
If this does resolve the issue
then to set your computer back, to boot normal:
  • Click the Start orb on your Desktop
  • In the Start Search box. Type msconfig, and then press ENTER.
Click the General tab.
  • Click Normal Startup - load all device drivers and services, and then click OK.
  • When you are prompted, click Restart to restart the computer.
Nov 27, 2013 | Retail Supplies
turned hibernation on in error .how do i turn it off again
You can turn it off under power management in control pannel. To avoid this issue in the future try this:
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window.
To make hibernation available, follow these steps:
  4. At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Jul 21, 2011 | Toshiba Satellite L670DST2N01 Laptop
How to active the Hibernate at all PCs?
Mar 26, 2011 | Computers & Internet
spooler serivice is stopped
Overview
This article describes two methods for restarting the Print Spooler service within Vista.
Method 1: Restart the service using the services console
  1. Click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  2. Right-click Print Spooler, and then click Stop.
  3. Right-click Print Spooler again, and click Start.
Method 2: Restart the service at a command prompt
  1. Click Start, All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following commands at the command prompt.
    net stop spooler [Press ENTER.]
    net start spooler [Press ENTER.]
    exit [Press ENTER.]
Apr 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
611 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
