Tip & How-To about Microsoft Windows XP Professional
How to back up the registry in Windows XP
  1. Click Start, click Run, type %SystemRoot%system32restorerstrui.exe, and then click OK.
  2. On the Welcome to System Restore page, click Create a restore point, and then click Next
  3. On the Create a Restore Point page, type a name for the restore point and then click Create
  4. After the restore point has been created, click Close.
Note: If System Restore is turned off, you receive a message that asks whether you want to turn on System Restore now. Click Yes. Then, in the System Properties dialog box, click to clear the Turn off System Restore check box, click OK, and then repeat this step
Microsoft Windows XP Professional Logo
gateway login
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 26, 2013 | Computers & Internet
gateway login
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Nov 18, 2013 | Computers & Internet
enter password unlock system
Log on as usual.
Method 2
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html
Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html
password cracker free
May 03, 2013 | Gateway 504GR PC Desktop
TS-L633A firmware update
Follow these steps to resolve your cd dvd issue. It's mostly caused by an error in the registry.
Before you proceed, create a backup of your registry.
Manual steps to back up the registry in Windows XP
1. Click Start, click Run, type %SystemRoot%\system32\restore\rstrui.exe, and then click OK.
2. On the Welcome to System Restore page, click Create a restore point, and then click Next.
Note If System Restore is turned off, you receive a message that asks whether you want to turn on System Restore now. Click Yes. Then, in the System Properties dialog box, click to clear the Turn off System Restore check box, click OK, and then repeat this step.
The next step is as follows:
First and foremost, go to My Computer; right click on properties, hardware, and then Device Manager.
Right click on the CD DVD drive and uninstall it, then click OK, then close.
Next Step:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
Jun 28, 2012 | Samsung TS-L633A DVDRW R DL drive - Serial...
Blocked out my laptop!
Do the following to restore it.
1. Go to Start Menu
2.Click on Run
3.Enter the following %SystemRoot%\system32\restore\rstrui.exe
4.Click Ok
5.Click on the Welcome to System Restore page that you will see
6. Create a restore point
7. Click Next
8. Give a name to your restore point
9. Click on Create
10.Close after the restore point has been created.
Note: If the system restore point is turned off, clear the check box in the system properties dialog box and click ok after you are done.
Regards
Sep 24, 2009 | Computers & Internet
1,078 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
