Tip & How-To about Microsoft Windows Media Player
Internal application error has occurred:Windows Media Player issue
1. Click Start, and then click Run.
2. In the Open box, type cmd and press OK
3. At the command prompt type regsvr32 jscript.dll, and press enter and click OK.
4. At the command prompt type regsvr32 vbscript.dll, and press enter and click OK.
If either of the files do not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Microsoft Windows XP, follow these steps:
1.Click Start, and then click Run.
2.In the Open box, type msconfig, and then click OK.
3.Click Expand File.
4.In the File to restore box, type the name of the file that you want to restore.
5.In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or click Browse From to locate the Windows XP .cab file.Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
6.In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
7.Click Expand.
8.In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart
Microsoft Windows Media Player Logo
so how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
yahoo chat box blank
*lights cigarette*
You may need to register vbscript.dll and jscript.dll
Follow the instructions below:
1.Run cmd.exe with administrator privileges (Start > type 'cmd' then right click on cmd.exe and select Run as Administrator, then click Continue when prompted by the elevation consent dialogue box). This will open a command prompt in c:\windows\system32
2.Type cd..
3.Type "cd SysWOW64" (Without The Quotes) press Enter
4. Type "regsvr32 vbscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
5. Type "regsvr32 jscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in jscript.dll succeeded."
Restart Your Computer.
Now try running Yahoo!
Regards,
Tamim
Jul 21, 2012 | Yahoo Messenger
Two days ago I turned my computer on and where my sidebar gadgets should be there were black squares and rectangles. My clock was square with a black face and not working. I tried installing different gadgets with the same results. I bought this computer on 7/31/08
Hello Donpd,
I have the solution to resolve the issue.
Perform the steps as provided below:
1. Close windows Sidebar. Right click on the Windows Sidebar notification area icon and click Exit.
2. Open the Start menu and click All Programs, then click Accessories. Right click on Command Prompt and click Run as administrator.
3. In the command prompt, type "regsvr32 msxml3.dll" without quotes and press Enter. Then click Ok.
4. In the command prompt, type "regsvr32 scrrun.dll" without quotes and press Enter. Then click Ok.
5. In the command prompt, type "regsvr32 jscript.dll" without quotes and press Enter. Then click Ok.
6. Turn Windows Sidebar back on.Check to see if Windows Sidebar is displaying correctly now.
Sep 10, 2008 | Computers & Internet
Lost my installation CD and downloaded the software from HP but doesn't work
To register .dll files follow these steps: 1. Click Start, click Run, type cmd in the Open box, and then OK. 2. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 /u sccbase.dll
regsvr32 /u slbcsp.dll
exitNote Click OK if you are prompted.
3. Restart your computer. 4. Click Start, click Run, type cmd in the Open box, and then click OK. 5. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
6. Restart the computer.
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
1,612 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
