Tip & How-To about Cell Phones
How To Fix " Prepaid Serverice Unavialable"
Go To Service and technical section. Enter your # ( Menu-> Prepaid-> 6.)
Scroll Down And You Need An Update (Its Easy)
Cell Phones Logo
New tracfone - want same number...I cannot get it transfered to new phone.
How to Keep the Same Number to Another New TracFone By Karen Kramer eHow Contributor dfab0ea0-859e-40e7-b8db-71a67ca9f2f2.small.jpg Karen Kramer Follow Save 8 Shares & Saves fotolia_1094058_xs.jpgFotolia.com">girl talking on cell phone image by Tammy Mobley from <a href='http://www.fotolia.com'>Fotolia.com</a> According to TracFone's website, TracFone's simple "No Contract" service has made it the largest prepaid cell phone service in America and the fourth largest cell phone company in the world. Their convenient, no-fuss service and cheap phones also make it easy to upgrade your cell phone and keep the same phone number without losing your prepaid minutes.
Promoted by
  • Open the battery compartment on your new TracFone and install the new battery by lining up the connectors and snapping in place. Replace the battery cover.
  • Plug your new phone into a standard wall outlet using the A/C charger cord that came with your new phone. Press the "ON" button or the red phone icon button to turn on your new phone.
  • Look at the screen to see if there is a signal icon, insuring you are receiving a signal. You can complete your number transfer online without receiving a signal. However, it will not be reflected on your new phone until you are in an area that receives a signal.
  • Turn on your computer and go to www.tracfone.com. Click on the green "Activate" button.
  • Click on the "Transfer Number" button under the "Activate/Reactivate" tab. Click on the "Existing TracFone Customer" button. Click on the "Activate my TracFone with a number transferred from another TracFone" option.
  • Click on the picture that represents your new TracFone to select that model. Hit the "Enter" key. Click on the picture that represents your old Tracfone to select that model. Hit the "Enter" key.
  • Click on the "Menu" button on your new TracFone. Click on the "PrePaid" section of your new TracFone and scroll to the "Serial Number" button. Click on "Serial Number." Type in the new phone serial number in the form on your computer screen. Some Tracfones may call the serial number ESN, IMEI or MEID numbers. Type in a nickname for your new phone.
  • Click on the "Menu" button on your old TracFone. Click on the "PrePaid" section of your old TracFone and scroll to the "Serial Number" button. Click on "Serial Number". Type in the old phone serial number in the form on your computer screen. Type in your TracFone number. Click on the "Submit" button.
  • Click on the "Menu" button, then the "PrePaid" button and then scroll to "Code Entry Mode" and hit "Select."
  • Press the " * " key, then the " # " key and the numbers " 3 " and " 0 ", then press the "OK" button. Your phone screen should display "Parameter 30" and a number. Enter the number you see on your computer in the boxes labeled "Enter the code here" and "Confirm the code."
  • Press the "OK" button again on your old TracFone. Enter " *#0." Press the "OK" button. Your phone screen will display "Parameter 00" and then a number. Enter the number on your computer in the boxes labeled "Enter the code here" and "Confirm the code."
  • Press "OK" then "BACK" and then the red "END/POWER" button on your old phone to return to main "MENU."
  • Click the "YES" button to confirm the number of minutes and days available to transfer to your new TracFone.
  • Turn your new TracFone OFF and then ON again. You will have to wait for up to one hour for the minutes to transfer.
Read more : http://www.ehow.com/how_7369407_keep-number-another-new-tracfone.html
From Tracfone themselves
Customer Support FAQ TracFoneWireless
Jan 09, 2016 | Motorola Mobility TracFone w175 PayAsYouGo...
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    it is prepaid tracfone and some how i disabled the prepaid service on it and i cant unlock the phone or sims card either one
    Here's what I did:
    1. go to www.tracfone.com
    2.click on service and support.
    3.click technical support
    4.enter your phone's serial number (you can get that by clicking on your phone's prepaid icon, then scroll down until you see serial number.
    5. Click select
    6. write down the number
    7. On the Tracfone serial number box, write your serial number.
    You'll then have to fill out a brief form (name, address, phone number, email, nature of the problem).
    8. Tracfone will send you an email with simple instructions on how to reprogram you phone. It's usually just a matter of clicking Code Entry Mode and entering the codes Tracfone tells you to.
    All in all it's pretty easy and a whole lot quicker than calling tech support on the phone.
    Hope this helps someone
    Aug 17, 2010 | Cell Phones
    MFC 210C machine error 4F
    Hi!
    To resolve the issue you'r facing with, you need to access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
    This will reset the purge count value. Then the printer will restart, hopefully without the error code 4F.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
    my phone is displaying prepaid services disabled
    i had the same problem i was pissed but heres the solution that helped me.
    2.then go to service & support and click on technical support
    3.then enter your phones serial number in the "Report Technical Difficulties" box.(to get your serial number go on your phone hit menu,then hit prepaid,then hit serial number.)then hit submit.
    4.then once you hit submit scroll all the way down to "prepaid disabled unit disabled".
    5.then click contiue once you get there then just follow the steps along the way.
    hopefully this works for you
    Jan 11, 2009 | Cell Phones
    170 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
