Tip & How-To about Car Audio & Video
Aftermarket Stuff
Computers don't perform well with aftermarket stuff which can cause driveablity issues. This is one of the reason that manufactors will void most warranties if you add any components to the vehicle that are aftermarket.
Car Audio & Video Logo
Wiring Diagram
we dont know what an engel
stock toy part?
aftermarket.
what? if latter, so post a link to it.
if adding , aftermarket, stuff, you need to link it.
so we can see it and then answer,
im an ET and can do this. but you need to identify what it is.
a URL to a seller or manufactor, or a photo.
something..////?????
Dec 10, 2013 | 2004 Toyota Land Cruiser
is there any recalls on the gas tanks of the 2006 cobalts cause my tank is leaking at the top
Fuel Sys, Driveability, Filters (Air & Fuel)
2006 CHEVROLET COBALT
02/01/2006 ELIMINATION OF FUEL FILLER TUBE FLAPPER DOOR 03/01/2006 ERRATIC FUEL GAUGE READINGS 06/01/2006 USAGE OF E85 FUELS IN GM VEHICLES - REVISED 06/01/2006 L61 ENGINE MALFUNCTION INDICATOR LAMP (MIL)/SERVICE ENGINE SOON (SES) LAMP ILLUMINATED WITH DTC P0171 "FUEL TRIM SYSTEM LEAN" SET 07/01/2006 TOP TIER DETERGENT GASOLINE - DEPOSITS, FUEL ECONOMY, NO START, POWER, PERFORMANCE, STALL CONCERNS - REVISED 07/01/2006 USE OF E85 FUELS IN VEHICLES NOT CERTIFIED BY GM AS BEING FLEX FUEL COMPATIBLE / AFTERMARKET CONVERSIONS OF VEHICLES TO OPERATE ON E85 FUELS 09/01/2006 397.pdf&btitle=2006 CHEVROLET COBALT&yr=2006">GM FUEL SYSTEM TREATMENT PLUS, FUEL SENDING UNIT CORROSION AND FUEL SYSTEM DEPOSITS - REVISED 11/01/2006 940.pdf&btitle=2006 CHEVROLET COBALT&yr=2006">ERRATIC FUEL GAUGE READINGS - REVISED 03/01/2006 USAGE OF E85 FUELS IN GM VEHICLES - REVISED 12/01/2006 TOP TIER DETERGENT GASOLINE - DEPOSITS, FUEL ECONOMY, NO START, POWER, PERFORMANCE, STALL CONCERNS - REVISED 01/01/2007 EMISSION RECALL - ENGINE FUEL INJECTORS - REPLACE 01/01/2007 LSJ, L61, LK5, L52, LL8 ENGINE - REDUCED ENGINE POWER, MIL/SES LIGHT, DTC P1516, P2135, P2138 02/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 03/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 05/01/2007 MULTIPLE DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 - REVISED 06/01/2007 <A href="http://arrc.epnet.com/autoasp/data.asp?sid=122357497&uid=s9193090.remote.autorefctr&type=pdf&ff=082000
Jul 12, 2010 | 2006 Chevrolet Cobalt
the automatic lock keeps locking and unlocking while driving
If your vehicle is equipped with an aftermarket security system, it could be causing this. I have removed several these systems from my customer's cars for the same reason. GM has technical service bulletins that discuss this as well as other driveability/emissions problems that these systems have been causing.
If there is no aftermarket in your car, I would scan the Body Control Module (BCM) first to see if the computer knows anything.
No codes - I would look into a possible loose connection or bad switch in one of the door panels.
Oct 31, 2009 | 2006 Chevrolet Cobalt
I use an extensive amount of diesel fuel in my 2007 F350 - can I disconnect the emission control device? Would it help?
I would not recommend disconnecting anything. This can void warranty and cause severe engine damage. There are several engine tuners or 'chips' as people call them that can increase performance and often times mileage too. They also will not void the manufacturer's warranty. Be sure there are no issues with you vehicle as of right now such as the check engine light being on or other driveability problems. Quality of fuel has also been known to significantly reduce mileage.
Sep 19, 2009 | 2004 Ford F150
2 codes show up on the reader.
The P0341 code is a code indicating that the cam position sensor circuit is out of range or not performing properly. The P0404 code indicates the EGR is out of range or not performing properly.
Those codes seem rather odd to have together. If the cam sensor was bad I would expect some driveability issues or possibly even issues with getting the vehicle started. The EGR could cause some idle issues.
I just cant get past that those codes seem so unrelated, they are for two different systems. If you are not experiencing any driveablity issues, I would clear the codes with either a scan tool or just disconnect the battery for a few minutes. If they come back then yes, I would have it looked at. You could try replacing the Cam position sensor, and see if that helps, but the EGR is a bit more challenging and would be a more costly item to replace.
Hope this helps out.
Jan 02, 2009 | 2005 Saturn SC1
199 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
