Tip & How-To about Washing Machines
Washer knob / Dial going round & round
If the washer knob of the unit is going round and round all by itself it means that there is something that has malfunctioned in the unit or else there was an error in setting proper cycles.
You will first need to reset the unit, to see the reset procedure click here
Once you have reseted the unit and even then the washer knob is going round & round it means that a part or parts in the machine have gone bad which may need to be replaced.
The question would be how can one understand which part in the unit has gone bad.
To make things easier, here is what needs to be done to know which part has gone bad.
  1. After reseting the unit, set a new cycle and switch on the machine.
  2. If the washer knob starts going round and round, the mode+Door lock light will flicker in a sequence, for example, it may flicker 4 times before taking a pause and then flicker 4 times again and continue this sequence.
  3. Once you know what is the count which is also the fault code there is a fault code chart which you can refer to understand which part has gone bad.
  4. The fault code chart is as follows:
Hope this helps, do let me know if this information was helpful or else you need more clarification on the same.
Washing Machines Logo
What does error message E20 mean?
Hi, try this and let me know what happens. Turn the knob to the off position. Then press and hold the start/pause button and the button on the left of it, with them 2 held in turn the knob 1 click clockwise. Keep the buttons pressed in till the lights start to flash then let go. Know turn the knob clockwise all the way round to the off position 1 click at a time. Then turn the knob ON THEN OFF AGAIN.
Retry the washer again and see what happens now.
Jun 27, 2011 | AEG Lavamat 12710 Front Load Washer /...
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
Jun 05, 2010 | Kenmore Washing Machines
EQUATOR 3612CEE WASHER DRYER/NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting if the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Jun 08, 2008 | Equator EZ 3612 CEE Front Load...
DRYER NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Apr 22, 2008 | Equator EZ 3612 CEE Front Load...
1,354 people viewed this tip
Top Washing Machines Experts
