Tip & How-To about Computers & Internet
DVD error? won't "Burn" here is a tip
1) Shut down ALL unnecessary processes, especially McAfee, and any other "Hungry" processes.
2) Switch to white-coated DVDs. You see, drives that write to DVD-ram as well as other formats need the "White-coated" DVDs (Sony are good, but any others the same will be OK), as opposed to the "Silver-coated" ones (Verbatim, Memorex, HP). (Use Nero, Info Tool, to diagnose your DVD drive.)
3) Changed burn speed to 4x.
Computers & Internet Logo
my computer is very slow, sometimes freezes or won't load and will not shut down
If your laptop computer won't shut itself down even after you select the "Shut Down" option from your "Start" menu, this means that too many programs are still open on your computer. Before Windows can shut down, it needs to manually close all open software, and having too many programs open can severely delay this process or cause Windows to lock up. Closing these programs will help your machine shut down as normal.
b> Right-click on your task bar. Click "Show Windows Stacked." This will maximize all of the program windows for all open programs on your desktop. The windows will be stacked one on top of the other on-screen. Click the "X" box in the corner of the first window to close that particular program. This will reveal the next program window in the stack. Continue to close these programs until you see your desktop wallpaper again. This, coupled with the fact that your task bar should now be cleared of all program icons, indicates that you have successfully closed all program windows. Your laptop will now shut down normally.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Feb 01, 2013 | Acer Aspire One PC Notebook
slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
JVC Everio MS100RU memory camcorder. When burning to a DVD, I get an error at about 99-100% and it will not complete. The error code is EB020B88. Any ideas?
1) I shut down ALL unnecessary processes, especially McAfee
2) I switched to white-coated DVDs. I read somewhere (can't now find the url), that drives that write to DVD-ram as well as other formats need the white-coated DVDs (I used Sony), as opposed to the silver-coated ones (Verbatim, Memorex, HP. [I used Nero, Info Tool, to diagnose my DVD drive.]
Mar 02, 2010 | JVC Everio GZ-MS100 Camcorder
Video card shut down
you probably need a higher watt power supply in your case. Most stock ones are only about 350 watt. you'l need like a 450 watt or better with that power hungry card.
Sep 17, 2009 | Palit Microsystems GeForce 9600GT, DDR3...
141 people viewed this tip
David Payne
David Payne
