Tip & How-To about Dryers
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley Fridigidaire
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
Dryers Logo
my admiral dryer model AED4475TQ belt came off and the pulley is laying lose I need a diagram to fix it please help
Hopefully this helps! My drawing isn't great or good for that matter. The washer has a place to insert the pulley in front of the motor. Put the belt around the drum. Then push the pulley back away from the drum and insert the belt in between the forks and then wrap it around the pulley of the motor. I really hope this helps.
Oct 27, 2012 | Admiral AED4475TQ
my dryer belt broke
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Nov 12, 2008 | Roper REX3614KW Electric Dryer
changing the belt on my admiral dryer
Go to partselect.com and look up a belt for you admiral dryer.
At this site they may have a diagram for how the belt goes on the cylinder, idler wheel and motor.
Start here, more later as needed.
May 06, 2008 | Dryers
4,391 people viewed this tip
Top Dryers Experts
