Tip & How-To about Plumbing
Gorilla Tape Pipe Fix
If you have ever had a pin hole in a copper pipe in the middle of the night. If you just can't afford to call a plumber at that hour and pay those off hour prices. If you need to get some sleep for work or maybe you just can't fix it properly, right at that moment. Here's the answer.
Get yourself some Gorilla Tape and a heat gun. If you have some sand paper or a wire brush bring that too.
1. Turn off the water to the leaking pipe. Then find the exact spot of the pinhole.
2. Dry the outside of the pipe with the heat gun. Be careful not to stand in or drape the electric cord into any standing water.
3. Lightly sand the section of the pipe to take off the polished shine of the copper. Be careful of the heat you just applied to the pipe.
4. Now, tear yourself off a piece of Gorilla Tape and wrap it tightly around the place on the pipe that you prepared. Be generous with the thickness and stagger the pieces to add to the width of the patch.
5. It is time again for the heat gun. Heat the Gorilla Tape with the heat gun until it shrinks and becomes shiny. Don't linger at any one spot for too long. Keep moving the heat gun around. Continue doing this until you stop seeing a change in the tape and it becomes uniform in appearance.
That's it. I have seen this trick hold 50psi for 8 hours before it started to drip. If it starts to drip. Tie a rag around the tape and attach a string to the rag. Run the string into a bucket and the water will follow it.
You can try to use regular duct tape, but I can't guarantee the results. Gorilla Tape is the only tape I have been able to use successfully, in this situation.
Now, go back to bed. You've got work in the morning.
Plumbing Logo
How do I set up the plumbing to convert a single bathroom sink to a double sink?
hot and cold supply is easy. You need to solder in a copper T-piece, and to that add a short length of copper pipe with an isolation valve and then connect that to a flexible braided pipe to the faucet.
Waste water not quite so easy. Have both P-traps fall to a cross pipe that goes to your existing waste.
A plumber could do the job in an hour and a half.
Oct 29, 2015 | Plumbing
What are the uses of plumbing?
Plumbing nowadays is specially used for small quantity water consuming in society building or in factory main supply from where the distribution of water is done via pipe line system called as plumbing. It is also said that, plumbing is the collection of connected pipes, it can be done in commercial as well as residential areas. The main goal of Assistance Plombier 77 is to reduce the wastage of water and to keep the environment clean and healthy.
Nov 12, 2014 | Watches
The plumber installed shower diverter and when the tap is running so is the shower. He did not install with copper pipes, but now says there doesn't have to be. He has thrown out the insturction and warranty sheet. What options do I have for fixing this problem. The tech I spoke with was adamant that it is because copper piping was not used and the plumber is adamant that it is not necessary and I am stuck in the middle with a huge bill and no functioning shower. Is it possible to send the instruction sheet to me, as well. Thank you. I need an answer ASAP...PLEASE
Copper pipe is not required for correct fucntioning of the diverter valve. Some diverter valves are not 100% shut off of tub faucet.... But it should mostly shut off. I suggest that debris may have damaged the rubber parts of the diverter, take it apart and inspect.
In my opinion PEX (which is plactic, multiple layer pipe) is much better than copper. Copper reacts with chemicals in the water, in some areas of the world....
You did not mention what BRAND, or model controls you have installed, but having the warranty sheet missing shoud not harm you getting what you need, and it cannot be a big deal, as there is little to a diverter valve...
Feb 26, 2011 | Home
hole in copper water supply pipe
solution#2 is one way to do it however those clamps will leak after awhile. You can cut pipe on center of hole and (A) push pipe up and install a copper coupling which does involve soldiering. Or (B) you can get a brass coupling fitting called (Shark Bite Fittings) which simply slides over pipe and locks and seals on pipes. This is a fairly new product and godsend to plumbers and plumbing repair. Whenever fixing pipes in walls check for any form of leaks thoroughly before covering up wall.
Apr 14, 2009 | Plumbing
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
3,605 people viewed this tip
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
