Tip & How-To about Cameras
A simple and effective solution for playback m2ts/mts files on Xbox 360
Xbox 360 does not have supports for m2ts/mts files as PS3 does, so if you have the needs of watching your Sony, Canon, etc. AVCHD camcorder captured footages on your wide screen TV through your Xbox 360 console, format conversion is essential. This article aims to give you a simple and effective solution for playback m2ts/mts files on Xbox 360. There you go:
Required software:
Pavtube MTS/M2TS Converter
Pavtube MTS/M2TS Converter is designed for those who have an AVCHD camcorder but unfortunately get stuck in MTS and M2TS video format. It does a good job in converting MTS, M2TS, M2T, TS, TP and TRP to versatile video and audio formats. People who have no way to edit MTS/ M2TS files with Adobe Premiere, Avid, Sony Vegas etc can find a best solution by converting them to useable formats such as WMV(VC-1), MOV (AVC) and MPEG2. The output formats covers common audio, SD video, HD video, Flash video, DVD as well as customized formats for Xbox 360, iPod, iPhone, Apple TV, PSP, Zune, Creative Zen, Archos, Nokia etc. All these output formats enable you to playback, edit and upload the footages shot by Sony, Canon, JVC and Panasonic AVCHD Camcorders. By the way, the copy protections removed Blu-ray .m2ts streams are workable with this program.
Following is the step-by-step instruction:
1. Click "Add" button to load mts/m2ts files into Pavtube MTS/M2TS Converter
2. Select output format for Xbox 360
Click on the drop-down menu of "Format", and then go to "Zune/Xbox 360 Device" – "Xbox 360 Video – Windows Media Video (*.wmv)".
3. Customize audio and video settings
Click on "Settings" button, and then you will be able to adjust audio and video parameters like codec, aspect ratio, bit rate, frame rate, sample rate, audio channels in the following window. Do not forget clicking "OK" button to confirm your settings. BTW, if you want to combine multiple files to be as a single file, you can tick "Merge into one file".
4. Click "Convert" button to start converting mts/m2ts files for playback on Xbox 360
As long as the conversion is finished, you can get the output files via clicking on "Open" button with ease. And now the files are prepared for playback on your Xbox 360.
For more: http://www.pavtube.com/mts-converter/
Cameras Logo
107 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
