Tip & How-To about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
How to change / set time and date on Canon PowerShot SD1200 IS / 95 IS digital camera
It is sometimes necessary to set the time or change the time on a digital camera.Some of the features on the camera actually require that you have set the time and date.To do this , follow the following steps.
  1. Firstly , Press the menu button
  2. Use the sideways arrow buttons to go to the settings tab indicated with a hammer and a wrench.
  3. Use the up and down arrow buttons to scroll to Time and Date and then press the function set button.
  4. Use the arrow buttons to select a area you would like to edit and use the up and down arrow buttons to select a time / date or value for a field.
  5. Once done , press the function set button again and the time and date will be saved.
For technical support from Canon , please follow either one of the following links to the support contact page. The steps descibed above are also included in the user manual which can be downloaded from Retrevo using the link below.
Canon USA
Canon Global
To download the manual for your camera , please click on the following link :
Where to find the manual (pdf) for Canon PowerShot 95 IS / SD1200 IS
Please rate this tip if you found it useful and please do not hesitate to contact me via the comments section if you would like more information or help in setting the time and date on you camera.
Kind Regards
StephanSA
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
how do I fix over exposed pictures outdoors
Check and make sure you don't have the exposure compensation settings set higher than 0. There is a manual override feature that lets you apply over/under exposure compensation to every photo rather than manually setting it for each shot. Sometimes, this feature can get accidentally changed. If that's not the issue try to reset the camera back to its default settings through the menu feature.
Aug 07, 2014 | Canon EOS Rebel XSi Digital Camera
My New Samsung Transform keeps Restarting from time To time , any soulutions ?
It is a power saver feature usually applied to the snap shutter. When the device is powered on, it assumes functionality mode. Soon after the device becomes idle, the shutter retracts to a close. Pressing on the snap button once already powered on should protract the shutters ready for acquisition of media. An entirely durational delay may actually shut down the camera requiring restart altogether. Explore the feature functions of the camera to ascertain its versatility.
Jan 19, 2011 | Cameras
using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
May 09, 2009 | Sony Cybershot S650 Digital Camera
I turned my digital camera on and the LCD screen is showing the image upside down and backwards.
The auto rotate sensor is going bad. Look in your camera's menus for a selection to turn autorotate off. Actually going inside the camera and fixing the sensor is possible for those with some electronics background, but really not worth the risk of further damaging your camera. This feature is not necessary as most image processing software has this same feature if needed.
Oct 18, 2008 | Cameras
1,639 people viewed this tip
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
