Tip & How-To about Office Equipment & Supplies
How i do to eliminate code error e007 in canon ir2020
I have a code in my machine canon IR2020, and i dont now what do
how can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
Service Manual with error codes for Canon IR 2016
Hello friend, you can find the canon iR 2016 service manual in below link:
Canon iR2016 iR2020 series service manual:
http://goo.gl/L6QGlk
Good luck on repairs.
Aug 28, 2012 | Canon Office Equipment & Supplies
PAPER JAM ON THE LCD SCREEN YET NO PAPER. CANON IR2020
IF IT IS A 2 CASSETTE MACHINE REMOVE ALL CONNECTORS OF 2 ND TRAY BY OPENING THE
BACK COVER(LOWER SMALL COVER) AND TRY. IF SYMBOL GOES OFF SOME PROBLEM
WITH LOWER LEFT HAND COVER RECTIFY IT. YOU CAN USE MACHINE WITH SINGLE TRAY TILL THE PROBLM IS SOLVED.
Jul 18, 2011 | Canon C330D Copier
forgot ID password of my ir2020 canon photocopier
first, you need to be an administrator with an administration id and pass to change any id and pass
please call canon Technical support, they can help you without damage.
Oct 05, 2009 | Canon iR 2016i Black and White Copier
219 people viewed this tip
k24674
jasbo
jasbo
