Tip & How-To about Computers & Internet
TEAC hdrm7250 settop box, Problems
Problems: harddrive very hot,timeshifting freezes,bracks up,can not record, harddrive ticking sound
REPAIR: replace harddrive with new one you can get 500gb for $60.
A normal computer one with a jumper from sata to ide power
I have repaired my box this way and no problems
if you need more info email me at steve531@bigpond.net.au
Computers & Internet Logo
my lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
siemens amilo pro HDD FAULT ?
usually "tick -tock" means the harddrive is dieing.
If I were you I would do a backup of my files and get the harddrive replaced a.s.a.p
Mar 08, 2008 | Computers & Internet
LG RH7796W DVD/HDD Recorder
The problem has fixed itself, thank you
Feb 26, 2008 | LG RH177 DVD Recorder/HDD Recorder
452 people viewed this tip
David Payne
David Payne
