Tip & How-To about Audio Players & Recorders
Playing cd or dvds
Allways make shore that the disc has no finger marks, as this will make it jump, skip
sony bdp380 skips when playing bluray discs
Laser pickup unit fault. Contact the authorized service center for Sony. The laser pickup unit to Blue-Ray player is not available by open electronic spare-part market. Electro help
Aug 16, 2014 | Sony Bdp-s380 Blu-ray Disc Player
bmw316 will crank but not start code reader saying camshaft sensor
make shore that your timing is 100% use correct cam locks(can be obtained from tool supplier) and crank lock pin (7mm Drill bit will work )There is a hole on the back of the engine(under the starter motor) usually has a plastic plug in it pull the plug out and turn motor over until fly wheal locks up make shore piston 1 is at tdc also make shore that the vibration damper (front pulley is not damaged or that the tooth gear on the pulley has moved
Feb 06, 2013 | 2003 BMW 3 Series
SL/DV280 DVD/CD PLAYER PROBLEMS TRACKING IS OUT BUT SOUND IS FINE. When I play CDs its fine but DVDs are skipping making it impossible to watch a film, is there anything I can do to resolve this probl
First check the disc doesn't have dirt, finger prints or is very badly scratched. If it happens on all discs you will need a lens cleaner disc. If that doesn't work then it could be damage to the lens or a fault on the unit.
Dec 10, 2011 | Audio Players & Recorders
keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
1,440 people viewed this tip
 Grubhead
Grubhead
