Tip & How-To about Cameras
Setting time with your JVC VIDEO CAM.
Sometimes we are lazy enough to read our users manual, we want it easy and quicky. For this reason this is common issue to JVC camera users find hard on setting their camera's clock and calendar. Setting is easy but saving your setting is tricky. So set your camera's date and time the usual way and make sure to switch off your camera first completely and remove power(battery or ac adapter) to have your setting save. Next time it will not ask you to set again until internal clock battery expires.
Cameras Logo
8g sd card doesnt work on jvc camcorder...it says card error
Each camera have maximum memory card to be readable. If the memory capacity is to high from the limit, the camera will hard to write the data inside the card and said that "card error".
Try to insert memory card with lower capacity (4 or 2 GB) and read the user manual to know optimum memory card for your device.
Hope this help and RATE please !
Jan 16, 2011 | Cameras
looking for a user manual for a JVC EVERIO 20 GB HARD DRIVE CAMCORDER - GZ MG 21 EK
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GZ-MG21US
Sep 24, 2010 | JVC Everio GZ-MG21 Camcorder
I have 3 of these cameras. One is DOA. No power
This is a professional machine. No power? check the breaker at the bottom rear side, this is accessible you can even see its marking. Could be the breaker if not, there are fuses inside sometimes protects for some reason. This machine has two DC DC regulators one found at the rear side(near battery compartment, hard to access) and another one easy to access below the handle near center(PS BOARD), needs only four screws to open. Mostly PS board damage if no power symptoms shows with all fuses OK. Good Luck
Mar 12, 2010 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
103 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
