Tip & How-To about Kitchen Appliances - Others
How do I clean my kitchen ceiling?
Call me lazy if you want to, I call it efficient. But the easiest and quickest way? I close the doors and windows and put a large pot of boiling water on the stove. Sometimes I unhook the dryer exhaust hose from the wall if I'm doing laundry, and aim it towards the kitchen. The combination of heat, moisture, and condensation helps me use a sponge mop on the ceiling. Takes about five minutes to clean my kitchen ceiling.
It should also work nice for cleaning smoke off the kitchen ceiling, for cleaning soot off the kitchen ceiling, for cleaning grease off the kitchen ceiling, or for cleaning tar and nicotine off the ceiling.
If this was of assistance or helpful in solving your problem, please take the time to rate it, as I took the time to write it. Thank you.
Kitchen Appliances - Others Logo
How do you boil the cactus to make a snack
  1. Use a pot holder and a sharp knife to scrape the cactus spines off the nopales. ...
  2. Cut the prepared nopales into strips about the size of green beans. ...
  3. Put the sliced nopalitos into a large pot and cover with water. ...
  4. Drain off the cooking water and rinse the nopalitos with cold water.
More items...
How to Cook Napolitos Cactus ' LIVESTRONG.COM
www.livestrong.com/article/463721-how-to-cook-napolitos-cactus/ https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+you+boil+the+cactus
Nov 29, 2016 | Cooking
ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Freezer is not even keeping ice cream from melting..and the 2 slots at the top in the back by the top shelf?? Are filled with IVE
Do an old fashioned dethaw of your icemaker. Remove food in compartment, unplug or turn off freezer. Leave doors closed, and get a thick towel and a pot of boiling water. Place the towel under the pot, close the door, and let the heat from the pot warm up that frozen freezer vent. That will clear the ice so the fan can draw cold air out into the freezer
Aug 01, 2014 | Samsung RS261MDPN - 26 cu. ft. Side by...
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to know how to fix it.
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
rust in bottom of 10/18 stainless steel pot
Use DeBruce Polish to pacify the steel, we get DeBruce Polish at debrucepolish.com. We especially like it on Ceramic cook tops, refrigerators, stainless steel grills that rust- DeBruce removes it all. Debruce is ECO-FRIENDLY we love it, having replaced 6 products under our sinks DeBruce paid for itself.
Jan 23, 2009 | Ultrex 259-218 Deep Fryer
1,005 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
