Tip & How-To about Televison & Video
Please help videoprojector Nec Np40
I don't have remote control, and i change the lamp , and i can't reset contor life time . This is possible from remote control, any solution....please. Sorry for my english . I am from Romania
Televison & Video Logo
I replaced a lamp on a Zenith Projection LCD TV model # D52wlcd. The new bulb is working fine. However, the end of bulb life indicator light ( orange ) would not go off. Any advise on how to reset the timer to '0' would be greatly appreciated. The orange light is a bit annoying to see. Frazer
Resetting the lamp time
After pressing the "?" key on the remote control in Stand-By mode, press the "9876"
and press the "OK" button.
And then three LED in the front is stop after flashing for a moment.* Lamp Life Time Confirmation
1. Method1 : Enter ADJ mode with using the remote control. You can be confirmed
because " Lamp Life Time XX hr" is appeared.
2. Method2 : With using the remote control offered to consumer if you press the
menu button continuously, OSD menus will disappear then press the "9876" and
press the "OK" button to enter ADJ mode you can see "Lamp Life Time XX hr"
Oct 13, 2010 | Televison & Video
My 42e2000 just said "lamp at end of projected life". I have had this TV for several years, have had it isf calibrated 3 times (the last time was 1 month ago). At that point, the technician said everything looked good. My question is this: am I safe to wait a month to replace the lamp? Can I just replace the bulb or do I have to replace the entire thing? Any help is appreciated.
I recomend chnge the lamp now to avoid ballast problem after.and remember reset the lamp timer after change.for reset lamp timer press menu in the remote control ----setup------in the color adjust side find lamp reset ----a change a new lamp question appear--push yes and ok.
Apr 09, 2010 | Sony KDF42E2000 42" HDTV
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
153 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
