Tip & How-To about NetGear DG834G Router
Lost your SKY router password and username then help is HERE
Read and accept the discalimer carefully this does work 100% of the time make sure that you select the correct model the black router will v1.9 firmware is the Sagem F@ST 2504 model the others older models are Netgear DG model variations.
https://www.cm9.net/skypass/
Happy finding
NetGear DG834G Router Logo
Kindle won't accept the Netgear13 password (password) to set-up Wi-Fi.
Is the password case sensitive? If your are 100% sure that you entered the correct password then try lowering the security level of the netgear router temporarily and try again. I have had problems with some devices connecting to higher security levels of wireless routers. Once the device is connected then switch the level back up. However please confirm security level compatibility. If all else fails then use the WPS to connect.
Dec 13, 2015 | Amazon Kindle Paperwhite
my 1994 Geo Metro will go into gear but won't go
there are R, 1,2 and D gears, all 3 dead?
the automatic transmission is failing?
so tell the full story.
1: i get in car start engine and select, drive,
2: i step on the throttle pedal, the RPM goes to 1000 and stops
engine bad,(100 related reasons) weak engine.
2b: I do same the RPM goes to way over 3000 rpm engine screams
in bar stool words
this is called transmission, bad. (for 100 reasons)
1: make sure shift cable works like new, read the FSM on the checks.
2: make sure levels are correct per the operators guide, do not guess.
read the guide and do it right. not like engine checks. of oil at all.
if fluid pink or red, or brown and black or black and full of metal flakes.???? ever do a tranny serviced (full) this DECADE? hummmmm........
3: fuses good. all fuses.
4:if here, RIP tranny
Sep 11, 2014 | 1994 Geo Metro
need help to accept calls answering with bluetooth
Not sure if you have provided the correct model. You need to pair the headset with the corresponding mobile phone and then accept the calls.
Refer this table on the link and select the correct Jabra model and the mobile phone model and you will find the correct instructions.
Bluetooth Pairing Guide
Aug 01, 2014 | Jabra Radio Communications
The router configuration page does not load correctly.i have to reload the page several times to get the configuration page.Many times when i click on apply settings,it do not work.Please can anyone h
How to upgrade firmware on ASUS RTG32:
  1. Go here ASUSTeK Computer Inc Support Search
  2. Select your router (by clicking Download)
  3. Select your OS
  4. Click on Firmware and download the one that suits your country.
  5. Click on Ultilities and select the one that suits your country.
  • Global is the direct link.
  • Global (DLM) uses your browser's Download Manager.
Launch the Utility and follow the on-screen instructions.
Feb 12, 2014 | ASUS RTG32 Router
How do i connect my wii to the nternet
Make sure your router is set to accept all incoming connections if connected directly to the router. For WiFi make sure the router network password is typed in correctly and the type of security is correctly selected (WPA/WPA2 ect)
Jan 12, 2013 | Nintendo Wii Console
1,257 people viewed this tip
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
