Tip & How-To about Cell Phones
How to reset Apple iPhone Smartphone via pc/computer?
Reset isdone in the phone when its not working properly or getting hanged in between orthe display is not seen properly. in this cases the reset has many a timeshelped.
Theprocedure to reset is as follows:--
  • Sync iphone tocomputer via a usb cable which you received with the iphone.(if you do not havethe cable then you can get it from any apple store near you or from appleservice center).
  • Then after youconnect the iphone to pc after that save the important data by taking the back
    up of essential data ie contacts apps etc,.
  • Then go to settingsgeneral option and there you will get the reset option. Reset all settings as alast resort.
    This will give you afresh start and should sort out
    the majority of any bugs the phone has. A re-sync with you computer will restore apps etc.
    this will help.good luck.
Cell Phones Logo
samsung gt-s5300 cannot be hard reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
Oct 26, 2012 | Cell Phones
phone gets hanged
Hai Dud,
You can do it but u can't format as in PC's u can reset the set as:
1.Back up ur contacts & other related items u needed.
2.Then Click on "Settings"
3.Initail Set up,scroll down u can chose Master reset or Master Clear.
4. Better go for Master Clear.Now everything is cleared from ur hand-set.
Hope it Helped You,If so give an "High Five!" [;)]
Jul 18, 2009 | Motorola Mobility RAZR V3i Cellular Phone
hanging problem
hi
there are a couple of reasons why your phone might be hanging
1. some software that might a problem
2. memory card problem
3. if u have recently changed the cover and/ or keypad which might not be fitting in properly
well of all things try a soft reset by dialing (*#7780#)
>>beware to loose all data on the phone with the following step so backup before u do so
the hard reset (phone format)
hold the three buttons Green&3&* and power button
hold the keys till a display FORMATTING appears on the screen
u will loose all data on the phone
cheers hope i helped
Jun 23, 2009 | Nokia 3230
reset
When your phone hangs, remove the battery, wait for 10 secs, again replace the battery & switch on the phone.In some cases after switching on the phone, you may have to reset date & time.
Jun 09, 2008 | Nokia 6708 Cellular Phone
168 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
