Tip & How-To about Cell Phones
How to reset Apple iPhone Smartphone?
Reset is done in the phone when its not working properly or getting hanged in between or the display is not seen properly. in this cases the reset has many a times helped.
The procedure to reset is as follows:--
Hold down the power key with round home key at the same time until the phone powers down.
Release both the buttons only when you see the apple logo on the screen.
Then wait a min or two for phone to re-boot.
You will not lose any data on the phone in this reset procedure.
The phone is now reset.
This will help.good luck.
Cell Phones Logo
Getting bored from Nokia C5-03 touch screen Hang problems & display related problems
Hi @Jayeshsinh DO this steps:
>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
Oct 29, 2017 | Nokia C503 Cell Phone
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able to use the receiver button above the master volume has been quite a pain. So , I shut something off, and can't get the remote or the Receiver to work properly.
Hello
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
Hi All, I have Panasonic SC - VK 540 music system. It has gone to the authorized service station several times for the above mentioned error. But unfortunately they have not bee able to fix the problem. The display does not show any error message before (like F61 etc.)switching of but makes a ***** sound similar to a relay toggle. Please Help ! Many thanks in advance Unmesh Deshpande
The fault seems to be a main board issue in which the relay is clicking but not activating.
SInce you are not aware of the work done earlier it must be seen if this was a reset issue. so power off and try to reset- refer you manual in thelast column for reset in case of errors...may be holding the menu/selecctor while switching on.
You can also see if there is any dry points in the main board,a loose connector or a connection . press and reset all connections
Sep 24, 2010 | Audio Players & Recorders
phone gets hanged
Hai Dud,
You can do it but u can't format as in PC's u can reset the set as:
1.Back up ur contacts & other related items u needed.
2.Then Click on "Settings"
3.Initail Set up,scroll down u can chose Master reset or Master Clear.
4. Better go for Master Clear.Now everything is cleared from ur hand-set.
Hope it Helped You,If so give an "High Five!" [;)]
Jul 18, 2009 | Motorola Mobility RAZR V3i Cellular Phone
134 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
