Tip & How-To about Video Game Consoles & Games
PSP3000 - ChickHen Mod by DaRKcLoUD-X v2.
This is an alternative of ChickHEN R2, for PSP3000 / 2000-TA088v3 with firmware 5.03. its known as ChickHen R2 Modified by DaRKcLoUD-X. I tried its more easier, load much faster, less likely to crash, and has compatibility with most memory stick highspeed - fake.. It has a higher success rate when it comes to actually enabling homebrew.
If you are difficult to load chickhen, Try it..! This will help users that are having trouble to getting chickHEN to load up after many attempts.
Download: *ChickHenMod DaRKcLoUD-X v2.
Installation Procedure:
Extract and copy all contents to the root of your ms. If its hang, try "system restore" your psp.
Share and enjoy the homebrews.
Source: http://e-arena.blogspot.com | More forum.!
Video Game Consoles & Games Logo
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
runescape on my psp
freewebs. com/ roshanb/ runescapeonpsp.htm helps(take out spaces)
Latest CFWEnabler : 05/07/2009
Download:
http://2f19b96d.seriousfiles.com
Changelog:
- Fixed a bug when playing within Infraestructure
- New system version
- Improved the Pops flashing system
- New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com)
-Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE.
-Copy the .EBOOT file in PSP/GAME/UPDATE.
-Run the update from your PSP .
Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings
-Set UMD Auto Start and Cache OFF.
-Make sure you're on 5.03 OFW
-Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows :
(http://ad452dd7.linkbucks.com)
-Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD:
FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load
(http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load
(http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT .
-Copy ChickHEN folder to PSP/PHOTO ( create one if needed )
-Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series.
This will permanently install CFW onto your PSP
ChickHEN must be enabled.
-Download Recovery Flasher 1.60
(http://926291d9.thesefiles.com)
-Download 5.0 OFW
(http://a3b04c08.thesefiles.com) -direct download
-Copy the Recovery folder to PSP/GAME .
-Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder .
-Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN
Any questions ? probs ? post here !
Enjoy :)
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
753 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
