Tip & How-To about Computers & Internet
How to format Hard drive/flash drive
This is a tip explaining step by step how to format your Hard drive. This is as easy as 1 - 2 -3, so lets get the ball rolling.
Firstly, you need to know that this method can also be used with Flash drives, MP3 players, basically any removable drive.
If the drive you would like to follow is a internal Hard drive, and you would like to format it to NTFS format, here is how we do it. Remember, that you will not be able to format your C(System) drive, because, then you will delete your operating system, hence, all other drives can be formatted.
Open "My Computer" and follow these steps:
The drive shown above is your C(System) drive, If you want to format this drive, you will need to do this when you attempt a clean install of windows.
Say you want to format your flash drive, insert the flash drive into your USB port, and open "My Computer". My flashdrive is Labeled Lexar(H)
Now just follow these steps.
Now you are done, the drive has been formatted. Remember, this also works on internal Hard drives, but not your system drive.
Hope you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
Computers & Internet Logo
needs format recover data
Firstly,recover harddrive datawith data recovery software.Then you can format it withlow level of format tool. For hard drivedata recovery software, I have a professional one on my computer that canrecover data after deeply scanning your hard drive to look for lost data due todrive crash, system sabotage, virus corrupted partitions, etc. You can downloadit and scan your hard drive for free to preview whether your data can berecovered. Get it from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm You can use this software to format yourdrive: http://www.softpedia.com/get/System/System-Miscellaneous/Any-Drive-Formatter.shtml
Sep 01, 2011 | Western Digital My Book Essential 1TB...
my toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a Maxtor OneTouch 4 which instead of openeing is opening a window telling me to to format my drive, and if I do that I will lose all my data,How can i restart the drive without re-formatting?
http://www.asoftech.com/articles/how-to-recover-deleted-files.html
If above does not work, you may have to format the hard drive (use quick format), and then use above file undelete program to scan again the hard drive and recover your files
Feb 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
i need to replace broken lugnuts
How to Replace Wheel Lug Nuts
(DIY Complexity: Easy / Time: 1.5 hours)
Parts:
1. Lug Nut
Tools:
1. Floor Jack
2. Jack Stand Set
3. Ball Peen Hammer
4. Tire Iron
5. Socket Set
Steps:
Step 1 Secure the vehicle on a solid level surface to ensure that it does not roll or lean when raised.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Break the lug nuts loose but do not remove. Using a floor jack, raise up the front of the vehicle.
o Tip: Using an aftermarket floor jack, instead of the original equipment (OE) jack, can make the job easier and safer. Verify the condition of the floor jack before use.
Step 3 Secure the vehicle with jack stands on both sides for safety before starting any work. Do not rely on the jack to hold the vehicle up while working.
o Tip: The pinch welds or the frame rails are the two best locations for vehicle support.
Step 4 Remove the lugs nuts. Inspect the threads on the wheel studs.
Step 5 Install the new lug nuts by hand making sure they thread properly.
Step 6 Tighten each lug nut in a star pattern. Lower the vehicle to the ground and torque the lug nuts to the manufacturer’s specifications.
o Tip: Refer to the owner's manual for the exact location on the vehicle.
Step 7 Road test the vehicle to verify lug nut repair.
I really hope help with this (remember comment and rated this post).
May 15, 2010 | 1993 Honda Accord
i need to format the hard drive using vista
ok follow this steps now. 0. Configure your BIOS and select DVD/CD ROM Drive, SATA or IDE for the first booting of the system. 1. you should have CD/DVD ROM SATA or IDE. Any of it you can use for the operations, and it's should be attach on you system unit. 2. When you are done on step 1. You can now Enter the Vista DVD/CD Disk Installer inside the CD/DVD ROM SATA or IDE. 3 Restart your system unit to proceed to the operation. 4. Automatically the system will launch the Operating System Files and it will Record all your information inside your hard disk.
Apr 10, 2010 | Compaq Presario CQ60-220US PC Laptop
164 people viewed this tip
David Payne
David Payne
