Tip & How-To about BenQ DC C740i Digital Camera
Memory card locked
This is a tip explaining the error, "Memory card locked". We will also give you the resolution for this error. This error, or rather message, is usually the result of the following situations.
Situation 1:
Well, this is usually the problem, on the memory card, there is a little switch on the left side, which can switch between "Lock" or "Unlock".
If you get the display, memory card locked, remove the card from your camera, or USB adapter and have a look at the switch, if it is switched to locked, move the lever top the other side and place it back. This should solve your problem, if not, lets have a look at situation 2.
Situation 2:
Open the card slot of your camera and have a look inside with a bright light/ torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch.
With time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
I really hope this can steer you in the right direction. Please rate accordingly.
Kind regards
Andrea
BenQ DC C740i Digital Camera Logo
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
memory card is locked
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jun 28, 2011 | Cameras
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Memory Card Error Card locked. I get the same
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
May 16, 2010 | Canon PowerShot A540 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
2,063 people viewed this tip
Top BenQ Cameras Experts
Daniel Dollive
Daniel Dollive
Edward Talavera
Edward Talavera
Are you a BenQ Camera Expert? Answer questions, earn points and help others
