Tip & How-To about Garden
A bad eletrical
If ypu have a garden tracktor you can jump it if your eletrical is bad
1 HOW unplug all wires from mower 2 remove blade deck and use the pullie belt to start
put belt on the pullie weel an put as hard as you can
Garden Logo
Drive belt for 46" mower deck jumps off
The tentioner could not be applying the right preasure. Make share it is not sticking and that it is moving free.
Jun 22, 2013 | Craftsman Garden
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
john deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
i need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
200 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
