Tip & How-To about Dishwashers
Dishwasher Repair Problem Detergent Cup does not Open
If you are having problems with your dishwasher not getting the detergent that you placed in the cup to release then you need to read this tip.
There are three things that are often the cause for this to happen.
-There is a problem with your timer
-The Bi-metal switch or wax motor is bad or not activating
-The detergent cup itself
First we will look at the wax motor switch. On newer dishwasher they have a wax motor in which the wax is heated. This pushes a piston out which mechanically opens the door. The Timer activates the heat to the wax motor. So if this is not working the timer may not be starting the heater or the wax motor is not heating or has lost its seal. You will need to be able to identify which of these problems is causing it not to work.
Next is the bi-metal switch. These also are activated by the timer. These bi-metal switches will move or deform when electric which cause a bit of heat, is applied. With these switches the current often runs through the pump motor or the heating element. This greatly complicates things, because if the pump motor is not pulling enough current because of low water, or the heating element is burnt out, then the bi-metal switch will not open the detergent cup. The problem you see, that of the cup not opening, may if fact be caused by an unseen and unnoticed problem. Like low water or a burnt out element.
Then there is the timer that actually has an arm or linkage that activates the cup door at the right time to dump the detergent. This linkage can get worn or broken. This can be one of the easiest to troubleshoot. If the linkage is broken or not operating, then simply replace it.
The final cause can also be a very simple fix. Sometimes the cup will just get a build up of mineral or detergent on it that will cause it to become inoperable. If the cup door is hard to close or does not release easily, then a good cleaning may be all that is needed to get it working properly again.
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Dishwashers Logo
My dishwasher is a little more than three years old. The detergent release isnt working. I usually used "pods", I have tried liquid as well and it is still not working. How might I fix this?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Aug 01, 2011 | Frigidaire FDB520RH Builtin Dishwasher
The dispenser door opens but the detergent is not released into the dishwasher. After the cleaning cycles are done, I open the dish washer door and the detergent is still in the tray. What could be the issue? Thank you.
heatman101 //../
Nov 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
main detergent door will not release
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Sep 05, 2010 | Maytag 24 in. MDBH950AWS Built-in...
dishwasher detergent door won't release soap
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
23,814 people viewed this tip
Top Dishwashers Experts
