Tip & How-To about Computers & Internet
Speakers are beeping or the status lights are flashing (like Morse code) at startup
This is generally the BIOS using a "beep code" to alert you of a problem. Just write down the code (either from speakers or sometimes the status lights) being careful to record if it is a dot (short) or a dash (long). This is NOT Morse code, it is dependent on the BIOS. Check which BIOS type (e.g. Phoenix) and version you are using and lookup "BIOS beep codes" using your favourite search engine.
Computers & Internet Logo
cooler is beeping cant stop it
Beeping codes are "type of device" and usually brand specific. Best practice is to identify the device, the brand, the model, and sometimes even the year. In regards to computers, beep codes are generally linked to the BIOS of a computer and/or to a brand. There are Award Bios beep codes, Intel beep codes, Dell beep codes, etc.. So, you have to gather a bit of information.
https://www.computerhope.com/beep.htm
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005473.html
https://www.itechtics.com/check-hardware-details-windows/
I assume that cooler in this instance refers to a device to cool a CPU.
But some water coolers actually beep when they spring a leak! Don't even ask about wine coolers...
Sep 12, 2017 | Computers & Internet
my Dell laptop makes 12 beeps and won't start, why?
Unfortunately, they are bad news and omens of *****!
  • Beep Codes - General Hardware - Laptop - Dell Community en.community.dell.com > ... > Laptop > General Hardware There is a comment in the User's Guide that you should make a note of beep codes when contacting Technical Support but there is no list of the beep codes - this ...
  • Dell Optiplex and Vostro Beep Codes and Error Messages ... www.dell.com/support/Article/us/en/19/SLN143065/EN 1. OptiPlex Beep Codes. The computer might emit a series of beeps during start-up if the display cannot show errors or problems. This series of beeps, called a beep ...
  • Beep Codes and PSA Diagnostic Chart - Desktop Wiki - Dell en.community.dell.com > Support Forums > Desktop > Desktop Wiki Identifying Dell Computer Models Using the Model Code. On Sept 26, 2005 the System Setup program on certain Dell Dimension™, Inspiron™, and XPS™ computers was ...
  • Alienware Computer Does Not Turn On or Go Into Windows ... www.dell.com/support/article/SLN114868/en Dell support article tagged with ... The following tables illustrate the Beep Codes for Alienware Mobiles and ... For a laptop computer see if you can access the ...
  • Dell Inspiron 15R (N5110) Beep Codes Diagnostic Indicators blog.parts-people.com > ... > Inspiron 15R (N5110) How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming ...
  • Dell Motherboard Beep Codes - What They Mean www.brighthub.com > ... > Computer Hardware Support 2010-05-23 · Technicians and computer users alike can use beep codes to troubleshoot hardware problems on all kinds of machines. This article lists Dell beep codes ...
  • Dell BIOS Post Codes - BIOS Central www.bioscentral.com/postcodes/dellbios.htm Dell BIOS Beep Codes; Dell BIOS System Messages; Dell BIOS Post Codes . Dell BIOS Beep Codes:
  • Step-By-Step: Deciphering BIOS beep codes - TechRepublic www.techrepublic.com/article/step-by-step-deciphering-bios-beep-codes Discover what the beeps your computer makes at start up mean. ... Step-By-Step: Deciphering BIOS beep codes. ... Dell BIOS Beep codes for Dell computers ...
  • http://www.bing.com/search?q=dell+laptop+beep+codes&qs=AS&pq=dell+laptop+beep+codes&sc=2-22&sp=1&cvid=768D6F3CC9284B039CE5B3AB707EFF02&FORM=QBRE
    Jul 31, 2016 | Dell Computers & Internet
    When I turn on the computer during POST the motherboard buzzer makes a 6-7 second long beep error code. Thanks in advance for your answer.
    Hello;
    The "beeps" your motherboard is making is an error code, designed to alert you of an error in an essential system component, such as a memory failure, general motherboard failure, video card failure, etc. When a PC is started, no matter the brand, it goes through a POST (power on self test).
    The types of beeps is a code, and is often system specific; changing from the manufacturer of the system BIOS, (BIOS; Basic Input Output System). If you know the bios mfg, you can get a POST error code chart for that specific manufacturer online... this will tell you what component is in question...
    I do find it odd that you've changed a motherboard, without trying to change your keyboard! Seems like it would be easier to troubleshoot a keyboard issue, than swapping out a motherboard.
    I don't know how fast your post code error is coming out, but if you don't know the mfg of your BIOS, it splashes it on the screen at bootup, or you can check your manufacturer's website.
    May 06, 2010 | ASUS P4S533-X Motherboard
    beep at start-up is repeting why?
    What does the beep sound like? If it's "beep. beep-beep" it's just a ram check. it's fine and it will always do that, unless you turn the beep off, which isn't recommended since the beep also alerts you of changes and problems. If you hear any other type/length/number of beeps, check the upper left corner of the monitor. Sometimes it goes by quickly, but it will tell you what was changed (eg. new mouse plugged in, etc.) This should only happen the first time you change a BIOS setting or add a device, and will not alert you upon restart.
    Hope that helps. Thanks!:)
    Jan 11, 2010 | Computers & Internet
    Computer Won't Boot (Anything?)
    ok sounds like a bad power supply , i would get a new one
    Jan 21, 2008 | Computers & Internet
    255 people viewed this tip
    David Payne
    David Payne
